- 472
- 0
- 16
- Rockmart Ga. 30153
I am looking for a turbo for my Deuce the on it is blowing oil out the exhust and from what I learned on steelsoldiers the seals are gone. motor runs great just blowing oil as soon as you start it.
there should be two tubes to the turbo, one with oil under pressure and the other one is the drain back, if the turbo is puking oil out the exhaust the exhaust seal is bad, if the air intake side seal is bad ,it will suck motor oil and burn it as fuel, either way you can suck motor oil out at fast rate if ether seal takes a dump this means that you run the motor OUT OF OIL
