When bleeding your brakes with a pressure bleeder, "Do not push down on your brake pedal!" . It appears that if you have air in your lines and the pedal goes down too far, the pressure in the reservoir will push fluid in front of the piston and out of the front of the master cylinder on the ground. I wasted a lot of fluid and went chasing the wrong problem because of this!
If you want to "feel" your brake pedal travel be sure to take the pressure off your bleeder first!
I'm sure there was Caution about this in the thread telling me how to make and use my pressure bleeder. But I missed it!
