- 5,247
- 3,935
- Charleston, WV
I would like to address braking with a non-ABS truck. My 923A2 truck had the ABS MWO and would not lock up the brakes in a panic stop. I was driving my 925A2 on the farm road a few weeks ago and wanted to see what happens when you lock the brakes up on a non-ABS truck so I would be more prepared if it happened on the street. I tried this without the front clip, bed sides, or tailgate, so the truck was considerably lighter than it will be when I am done.
I got the truck up to around 35-40 mph and then jammed on the brakes to simulate a panic stop. It pulled the speed down very quickly, but it killed the engine. That is one of the safety concerns addressed by the ABS MWO because when the engine dies, so does the power steering and it makes it very hard to correct a skid situation. I freaked out a little when I lost steering even though I was on a farm road in a controlled situation. My first instinct was to flip the start switch to restart the engine, but the transmission has a neutral switch that requires you to be in neutral before you can start the truck. That caused me to panic a little more because I was rolling toward a soft field. Finally, I flipped the gear selector to N, restarted the truck, and steered away from the field.
All of this transpired in a matter of seconds. You can imagine the panic that would ensue if you were driving 50-60 down the highway, traffic stops, you slam on the brakes, the rear end skids out, the engine dies, you lose steering, and go careening toward the opposing lanes of traffic. Anyone that has driven a non-ABS truck with straight air brakes knows that you don't slam the brakes on when you are running empty, but all of that common sense will fly out the window if you are in a panic situation.
I plan on practicing some with mine to make sure I can maintain control during a panic stop. I am not recommending that any of the rest of you 939-series owners try this for obvious legal reasons, but please exercise caution if you own a non-ABS truck. Maintain the 40 mph speed limit suggested by the -10 especially if you are running NDT's. I am going to be keeping my eyes peeled for an ABS MWO kit to install on my truck as an added layer of safety.
Check out these videos from the ABS Mod website for an idea of what could happen:
