Trudge
- 0
- 0
- ballston spa NY 12020
any one got a 24v pyro gage they wan to sell? or know where to get onw?
How does mounting it before the turbo effect the reading? Is it hotter or colder than after?Here is a 3" stewart warner, its a nice quality gauge. I like it because of the colors on the gauge, just a quick look and you know were your egt's are. That way you can spend more time looking at the road. I installed the thermocouple in the front port of the exhaust manifold in the 1/4" NPT hole, it was just a bolt on install, no holes to drill. I just used a 24 volt gauge for lighting. Simple easy setup.
Not really, just add 100 degrees. At the time, it was much easier to install the probe post-turbo.having the probe post-turbo is just about worthless.
if you think that's how it works, you are quite mistaken.Not really, just add 100 degrees. At the time, it was much easier to install the probe post-turbo.
look, drilling / tapping for the probe is easily done with the turbo still on the truck. it should take less than 20 minutes. or, as someone else posted, it looks like there's a fitting already tapped for use - it doesn't get any easier, and it's the right way to do it.I've been debating where to put my probe. I was first set to pull the turbo and drill the manifold but after reading alot on this subject I may go post-turbo. ...
yeah, that's not how that works. you think a guage vendor is going to give a flip when you tell them you melted some pistons and ruined your engine?... Any of the major gauge manufacturers and diesel engine sites say it's ok to go post-turbo as long as you add 200-300deg. Most trucks that have a pyro from the factory has the probe post-turbo also.
I figure if I go post-turbo I'll just keep it around 1,000deg and be ok. ...
