readyman
- 7
- 18
- Elk Grove Village, Illinois
As Bjorn said, the mil-spec deepwater fording kit was a good start point. But it could be improved. I finally finished the install and thought I'd get it all in one topic heading.
I've used a 3 port manifold on the air filter housing for the brake vent, air compressor and the 'normal' venting air source for the inside manifold under the dash.
The manifold has to be removed to access the air filter.
The 'air actuated ball valve '- normally open, will go on the bottom of the clutch housing. When I apply air(on the dash) to the rest of the deepwater fording system, the valve will close and seal the bell housing drain hole. I'll just yell "Prepare to dive!"
Then I used a 6 port manifold under the dash with some cheap 'shut off's' so if one of the vent lines get torn off by debris I can shut the one line down and maintain pressure. I used the plastic DOT quick connect lines all around.
By request here is the BOM from McMaster, will post the crankcase breather solution.
Lil Ruthie Fording Kit Upgrade BOM
Supplier - McMasterCarr, www.mcmaster.com
Air Operated Valve - for bottom of clutch housing and a dust filter that lets oil out but keeps the dirt out
9833K12 1 Each Breather Vent, 3/4" Npt Male, 20 Max Scfm, 1" Height
8168K22 1 Each Bronze Low-profile Air-actuated Valve, 3/4" Npt Female, Normally Open
Gauges/Regulators - One for the pressurization system(low psi) one for the Air Actuated Valve(higher psi)
3847K11 1 Each Multipurpose Gauge +/-2% Mid-scale Accuracy, 1-1/2" Dial, 1/8" Npt Male Bottom, 0 - 15 Psi
9892K121 1 Each Miniature Air Regulator, 1/4" Pipe Size, 22 Max Scfm, 1 To 10 Psi Range - system
Misc 'Push-to-connect' Tube Fittings - order as necessary DOT might be overkill
51495K134 1 Each Nckl-pltd Brass Push-to-connect Tube Fitting, Tee For 1/4" Tube Od
51495K218 1 Each Nckl-pltd Brass Push-to-connect Tube Fitting, Swvl 90 Deg Elbow For 1/4"tube Od X 1/4"nptf Male
51495K264 2 Each Nckl-pltd Brass Push-to-connect Tube Fitting, Adapter For 1/4" Tube Od X 1/4"nptf Female Pipe
51495K264 1 Each Nckl-pltd Brass Push-to-connect Tube Fitting, Adapter For 1/4" Tube Od X 1/4"nptf Female Pipe
51495K191 1 Each Nckl-pltd Brass Push-to-connect Tube Fitting, Adapter For 1/4" Tube Od X 1/4" Nptf Male Pipe
51495K191 10 Each Nckl-pltd Brass Push-to-connect Tube Fitting, Adapter For 1/4" Tube Od X 1/4" Nptf Male Pipe
51495K144 2 Each Nckl-pltd Brass Push-to-connect Tube Fitting, Swvl 90 Deg Elbow For 1/4"tube Od X 3/8"nptf Male
51915K61 3 Each Low-temp D.o.t. Push-to-connect Tube Fitting, Swvl 45 Deg Elbow For 1/4" Tube Od X 1/8"nptf Mal
51915K11 3 Each Low-temp D.o.t. Push-to-connect Tube Fitting, Adapter For 1/4" Tube Od X 1/8" Nptf Male Pipe
51915K31 2 Each Low-temp D.o.t. Push-to-connect Tube Fitting, Swvl 90 Deg Elbow For 1/4" Tube Od X 1/8"nptf Mal
51025K194 1 Each Brass Push-to-connect Tube Fitting, Coupling For 1/4" Tube Od
Nylon Tubing - DOT might be overkill
5097T832 150 Ft. D.o.t. Choose-a-color Nylon Tubing For Air, Nonreinforced,.170"id,1/4"od,.040"wall,black
Air Manifolds - plastic or metal
5469K115 1 Each Aluminum Manifold, 3 Outlets, 1/2" Npt Inlet X 3/8" Npt Outlet - air filter housing
5469K153 1 Each Aluminum Manifold, 6 Outlets, 3/8" Npt Inlet X 1/4" Npt Outlet - under dash for system
Shutoff Valves - shutoff's for each line if wanted
4912K72 6 Each Miniature Chrome-plated Brass Ball Valve, Wedge Handle, 1/4" Npt Male X 1/4" Npt Female - under dash
Dash 'Pull Out' type Air Switch - system goes to normal air psi when system is not pressurized
2700K14 1 Each Hand-operated High-flow Air Control Valve, Manual Return,3-way, 0-145 Psi,1/4"npt,palm Button
