If you have the A3 wheels, the answer is simple. Michelin XL 14.5R20M1075,
I see you are the only one that has actually run these tires. I just got a set of Deuce wheels on GL that are like the Hemmet wheels but with 6 holes and I am looking for tires and I need help deciding on what to get. Let’s just say I will spend 95% of the time on the asphalt but want a tire that I can bug out in if all **** breaks loose. Dependability and getting my butt out of a crack is more important than comfort if that helps. I have no experience with any of the three so any advice is welcome.
Rick
I don't know what valvestems those A3 wheels take, but you should be able to source them somewhere. The A3 wheels are designed to work with the MPT 14.5 tires. You only have one tread choice in that size on the surplus market. The other tires are not well suited for A3 wheels due to difference in beads.Great thank you very much. since you know what you are talking about can you tel me what to do about valve stems? The hemmit stems done fit. They fit the hole in the rim but arent long enough to reach out so I can add air if needed.
If you have a sec I would realy like to know why you say Michelin XL 14.5R20's?
I am trusting your advice and I am going to find and buy thme I just kind of like to know why. I jsut have no knowledge on this subject and would like to learn.
