I have been trying to diagnose this Multi fuel engine for a few days now and I'm kind of at a loss as to where to go from here. The problem is no fuel to the injectors.
1. I checked and replaced the blown fuse on the lift pump.
2. I replaced the lift pump with one from Gimpyrob (thanks BTW)
3. replaced the long filters on the side of the engine.
4. filled and bled those with the center bleed screw on top of the housing.
5. Pulled the center bolt from the hydraulic head to check to see that the pump was cycling
6. pulled the cover off the engine stop valve and checked it. Was a bit gummed but started moving freely pretty easily.
7. cracked the return line bleeder
8. cracked what I think was a bleeder on the side of the injector pump.
9. cracked the injectors themselves
All of this has been done one thing at a time and attempted start afterwards. I have yet to get a single drop of fuel to the engine itself. I have fuel everywhere but there. So where do I go from here? I'm hoping my injector pump isn't shot too but I suppose it's possible. I could sure use some help, this is new to me.... obviously. I hope I'm not repeating something that gets asked constantly. I did search but haven't turned up much past the point I am currently sitting at.
