- 4,640
- 32
- 38
- Cambridge, Ohio
Joe,
Stay calm and take a step back for a few minutes and it will become clear
. Seriously, you're looking into this too closely. Start off by following the TM and not the Ambac manuals. The Ambac manuals were written for rebuild shops and professional mechanics, whereas the TM's were written for an 18 year old kid fresh off the farm who hasn't even seen a deisel, much less worked on one.
Follow the flow timing method in the -34 TM on page 7-39. You don't need to pull the IP, just remove the delivery spring. Use the button you have in the pump currently. That test will tell you if the button is the correct one or not. If the flow stops on the "PC" mark, you are timed properly and ready to move on to another possible cause. If not, then you know you need to get the right button and re-try to run it.
Like Ike said, we're all here to help you and hopefully others will learn from this tread. There is a lot of GREAT information being tossed around in this one. We'll get you going sooner or later.
