ODdave
- 41
- 0
- lansing michigan
Just to help prevent this from happening to anyone else !
I ordered a 6in lift system (4 springs, 4 shocks) from NTW a while back for use on a 1028. Finally got around to using it and after installing it i thought something looked a little off. The front sat about 1in lower than the rear. Did some calling around and quickly discovered the problem. Turns out that even though i specificaly requested 1TON, I was sent 1ton rear springs and 1/2-3/4 ton fronts. The springs I recived where ment for trucks with small block engines, NOT big block or diesel.
I have the correct ones ordered now (additional $340.00 as i cannot return the others) But for reference the superlift part # is 01-235 for the 1-ton and 01-235-6 for the lighter ones.
P.S. Superlift is out of stock and back ordered on the "HEAVY" springs but this Rough Country # 8015 is spose to be the same
Hope this helps someone!
