frodobaggins
- 16
- 38
- Ruston, La
--- If you came here by mistake and are looking for disc brakes...
*NOTE:You may also like to check out the "Disc Brake Engineering Thread" for a separate but equally interesting issue. http://www.steelsoldiers.com/deuce-modification-hot-rodding/72967-disc-brake-engineering-thread.html
This thread is meant as an engineering thread for discussion of how to convert the M35A2 Deuce single circuit brake system to a dual circuit system. Any and all means are acceptable and can be explored. I will reserve the first few posts for updates and any solutions that are found.
I realize there are some other threads around but this one is meant to be a sort of catch all as well as an engineering thread. Hopefully we can find an economical and safe solution.
