paulfarber
- 19
- 0
- Gordon, PA
If one bearing is bad, you should replace both as a set. It would be just a matter of time before the other one went bad. I learned a good saying years ago. "If you don't have time to do it right the first time, when are you going to have time to do it right the second time?". You don't want to have to replace that on the road.
Not to pick nits, but ALL bearing will 'go bad in a matter of time'. If the bearing is serviceable, use it. If its not, then replace it.
Knowledge = blindly replace both bearings
Wisdom = knowing which bearing is bad and keeping the the good one.
![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
