Trailer Theft
ENTRAIL
Oakland Michigan
:?:My question is about trailer theft and maybe you help. I know you can lock the receiver to the hitch. I know you can lock a pintle hitch when it is off the hitch. How do you prevent theft of your trailer when it is all hooked up? What's to deter someone from just uncoupling your trailer and drive off? Thanks for any input.:beer:
ENTRAIL
Oakland Michigan
Never heard of it, went to three trailer places in Detroit area, and no one knows what I'm talking about. I will google trailer lock pins and see what appears.:beer:
islandguydon
787
Michigan
You can also remove the ring, "lunette" from the trailer if it is removable. Thats what I did.
Or what the Gimp said.2cents
faw3
Woodbridge, VA.
I have my two safety chains padlocked together with a big lock near the hitch. You place the chain hooks into the holes on the hitch reciever then use the padlock to ensure they can't be lifted out.
Easy...and will deter the casual thief which is what I worry about.
Whitey
Central Maryland
A friend of mine runs a BIG cable with loops on each end through the holes in the wheels of his trailer and is secured by a heavy padlock. He leaves it parked on the street with no problems.
gimpyrobb
dumpsterlandingfromorbit!
27,786
763
Cincy Ohio
Well, if its a military trailer, it probably has parking brakes. Drill a hole through the handle so that the brakes stay on.
doghead
4 Star General /Moderator
1,184
You think a padlock is enough to deter a trailer theft?
319
Lieutenant
3,348
58
Michigan
Regardless of what you do, if the thief wants it bad enough, he or she will get it. To deter the casual thief, I padlock the safety chains to the tow vehicle. Keep in mind that the safety chains can be removed from the trailer tongue with basic hand tools unless they're welded on.
Truckoholic
13
Colorado Springs, CO
You sit in trailer with gun. Jerk comes and tries to steal trailer, you shoot jerk with gun. Not only your trailer no get stolen, but you save someone else from getting their trailer stolen as well. :D
wmmscott
26
Jeffersonville, IN
trailer locks
The ones that will fit through the hole are small in construction. A good hammer would bust one.
I'd suggest that you back your trailer into a light pole or tree, or do the cable thing. Nothing will prevent a real thief.
Huge safety chains and some large padlocks are my only other suggestion.
Ressoldier
Riverside, CA
Not sure how common trailer theft is once it is hooked up to the TV, I would say almost all occur when it is not coupled in storage. When I go to someplace I try to find the outer edge of the parking lot and then place trailer between my truck and another object. Usually less cars around to hide someone uncoupling then moving trailer to his TV and driving off with it. That is way to obvious of movement and people would notice it easily. Besides it isnt that easy to wrestle our 1000+lb trailers around. So all these answers will help:
place trailer between TV and an object
padlock through safety chains
Cable lock axle wheels
padlock through parking brake levers
pin lock through pintle
Jtspendy
11
Vineland NJ
If you are storing the trailer for any amount of time, take the wheels off and let it sit on blocks. Just be sure you store the wheels somewhere enclosed so a theif can't just put them back on.
goldneagle
1,189
Slidell, LA
They make a lock assembly for a lunette. I will try to attach a picture.
$27 at anythingtruck.com
I have used this locking system for over 7 years. I like the fact that the lock is recessed into the pocket. I think it is a #5 lock size.
