Heavysteven
- 10
- 0
- Hickory Flat Ga
Looks like you got your truck running pretty good. 62 mph and 10 mpg. How's the ride smooth?
I'll wager that it's ATF. I've ran my bone stock deuce 66 before for a hundred miles or so. Rather not. I have warranty engines in the can just in case!The super deuce that goes 65 mph, gets 10 MPG and does it all day long up hill both ways rides again. Are you using WMO and cooking oil too![]()
Interesting, I didn't know "tuning" could compensate for harmonic imbalances, mass, valve spring strength, tensile strength, and sheer forces?This is not my first deuce..... If you all remember 2007 East Cost Convoy and me passing the convoy at over 70 MPH in my deuce towing a M1008.
If your engine is "tuned" there will be no problem turning 2700 RPM all day long. My last LDT with a LDS pump I would turn 2900 RPM. And doing so for over 800 miles non stop (well one fuel stop but never shut the truck off)
It was a "trucks use left lane" zone.
probably quiet too !looks like you got your truck running pretty good. 62 mph and 10 mpg. How's the ride smooth?
He has nothing else left to loose.I realize you've had a great deal of luck with turning your engines up that fast. But personally I cringe at the thoughts of it.
See post #28.Well really because you don't know.... I just don't care.
That's the ignorance and apathy approach.Dont know dont care.
Well the GPS does not lie. I have had the truck up to 63 and she will hold it there, but 61 MPH is her sweet spot.
Stock trans, axles and 900 tires.
I'd really hate to see that truck take a 62mph dump but to each his own I suppose.
