HMMWv seats
What seats?
  • High back
    Votes: 22 88.0%
  • Off road racing
    Votes: 2 8.0%
  • other
    Votes: 1 4.0%
58
pa
Im looking to get new seats. I have the original foam pads now. How comfortable are the high back seats? Would i be better off getting a off road racing seat?
thanks
Milcommoguy
2,422
Rosamond, CA
IMO... there's not much comfort riding around in a HUMMWV for all of the reasons you can think of. It is the machine that it is. If your not particular about "original mil spec." then make it the way you can best enjoy it. Note that there's not a lot of wiggle room when going to a custom cushier seat. May require modifications to get the front to back slider travel to accommodate or compensate for added padding / driver-passenger comfort. Look closely at just how little room you have to play with left to right, up and down to get the right fit. It's been done and I am sure there's something better.
I have a feeling that most of us just wing it, have a supply of Prep H and ear plugs for the long trips. CAMO
SCM35A2
3,387
Florence, SC
I would think the high back seats would be more comfortable espically if you plan to drive it a lot.
papakb
1,196
San Jose, Ca
Having spent hours with my butt on both seats I can guarantee the high backs are the way to go. They are to your bottom what radial tires are to the road! LOL
riderdan
20
Central Kansas
If you buy high-back seats (the "OEM" military ones) for all four places, it's more expensive than a similar-quality set of aftermarket seats, which will be more comfortable. So that's a trade off.
If you want to keep the military look of the OEM high backs but get at least a bit more comfort, the covers come off pretty easily and you can add a (thin) layer of memory foam over the seat bottom and put the cover back on. You can't tell it's there by looking, but my hind end notices it.
Those thin square pads for the passengers are fine for 20-YO infantrymen, but my no-longer-20-YO body thinks they're for the birds. And to quote Dr. Jones, it's not the years--it's the milage.
58
pa
Im not worried about it being 100% original/military. Im only looking for 95%, lol. If i do go with an aftermarket seat it will have to look like it belongs in a military vehicle. Im not a huge fan of the leather seats in hmmwvs, im sure they are comfortable but they look odd.
im not looking for a super plush seat i just wanst sure how much better the high backs are.
Since its me, myself and I 75% of the time, ill probably keep the pads in the back like DREDnot
lol. thanks for the input
thats a good idea thanks for sharing
papakb
1,196
San Jose, Ca
The seats are a variation on Isringhausens truck seat line. When I had to rebuild my seat base 20 years ago it was the only way to get parts for them and original seat bases were few and far between. Isringhausen helped me out no problem. Check their website and see if they have something that might work for you.
DREDnot
618
Avondale , AZ
Bet bet is get the high back seat kit.
It had everything to do the two front seats complete. It was a fun one day project but big improvement. It includes a storage compartment under the drivers seat and WAY better adjustment. The "commanders side" (passenger) has some reinforcing plate to mount on the battery cover.
I made some recliner brackets for it since the fixed originals were a little too upright for my misshapen presence.
I sprayed them liberally with silicone fabric protector to minimize staining and rain soakings.
I stayed with the early rear cushions because I like to switch back and forth to the two man cargo configuration.
  • Like
Reactions: cwc
Wire Fox
162
Indianapolis, Indiana
This is unrelated to the general topic, but seeing your photos... ...do your rear tool-access doors also flap in the wind like mine? I'll be going down the road and then suddenly hear the loud thunk of one flipping open and slapping the door. This is 100% fixable issue with a set of draw latches that I already have sitting around, but I've just been too lazy to install them with other projects about.
58
pa
get that 4/s outta there! lol. I was going to use the factory "folding" rear seats but ended up finding a set of folding mastercraft seats for cheap. still need to get seats for the front.
Bscap
Massachusetts
I chose the same option and about to tackle. Any recommendations on the driver's seat box removal?
DREDnot
618
Avondale , AZ
Good 1/8 drill bit and spring loaded center punch to drill out all those rivets. A small angle drill is a big help as well for some of the hard to reach rivets.
