Bowhunter0311
- 2
- 3
- Texas
Had some codes come up the other day on the transmission 2511, 2533, 5633. I pulled a cover that is next to the output shaft going to the rear axle. From what I can tell the gears look fine but something probably a bearing came apart and bounced around and you can see where the parts were hitting the case.
There was some metal around and on the sensor that is just inside the cover I pulled, which explains the codes.
I am going to further investigate just wanting to know if anyone has taken one of these apart or has ideas or best ways to go about it. Should’ve taken some pictures when I had it open today but didn’t will get some in a few days when I open it back up.
2511- output speed sensor @ 0 in 1st
2533- “ “ @ 0 in 3rd
5633- 3rd range verification test
