IrishGoodbye
- 26
- 3
- CA
Hello, new member here based in So Cal.
I’ve spent some time searching around various posts (to educate myself and so as not to ask a question for the 300th time…). I guess I probably run the risk anyway.
In short, I’m looking at an LMTV that was built as a civilian version by BAE systems and was marketed as an XD 4400 Titan truck by worldwide machinery in Houston Texas. To make a long story short, it was built in 2012 the story that I was given was that it basically sat on the lot for years unused, and when the builder finally got it, it had about 800 miles on it in 2020. The truck is a 4 x 4 with longer frame rails and now has a RV camper box on it, which is about 20 feet long. All in all, it is a super sweet rig.
My main questions, and I don’t want to fully repeat @exon111 ’s previous post from the 2017 timeframe… But I guess I have a similar question, maybe just asked a little differently… are with regard to reliability and ability to get parts.
My main questions are threefold:
1. How difficult will it be to get parts for this truck? I understand that there are surplus places to buy parts, I understand that people probably use donor trucks to strip mine for parts, etc. But, let’s say I am in Wyoming and lose a hub bearing, if I have the truck towed to a big rig shop… Are they going to be able to fix the truck? Or is it going to be sitting there for days while they try to find some incredibly hard to find part that ultimately has to be sourced out of some junkyard or from some Military surplus website?
2. The truck has a Cummins commercial variant 6.7 with after treatment system and DEF, and an Allison transmission. Neither of these things will be difficult to get parts for no matter where I am in North America, but I’m curious… what will be the most hard to fine parts? I read a post somewhere here where a gentleman said he paid nearly $5000 for a new windshield and that was not easy to get. What are those things that I’m going to have the biggest challenge with?
3. Being that the truck was “new” in 2020, havin been built in 2012 and then turned into an RV in 2020 with 800 miles on it… I guess we can consider that it is a fairly new truck. That being said, the truck is currently being repaired due to a drivetrain bearing seizing and the seller has had a very difficult time getting the rear differential repaired, which essentially grenaded due to the bearing. The truck only has about 9000 miles on it now. I don’t really have a great explanation as to why all the oil puked out of the rear dif (non CTIS truck), it just seems to have puked out of some vent and the driver, being unaware, ran it until the bearing gave out. Are things like this likely to continue and plague me as a new owner? Or, once these trucks are totally sorted, are they like any other commercial truck where they will just run and run extremely reliably for 500,000 miles?
for context… other alternatives would be Earthroamer (or similar, GXV, etc.) pickup truck based off-road capable campers.
If you’re still with me, I appreciate you reading this, and my questions are probably dense and run-on questions that may be difficult to answer. But, for those of you with the time or interest, I would surely appreciate any guidance you might have.
