Add tachometer to M1079
Ronmar
6,639
Port angeles wa
What Superman said, on the bellhousing just to the rear of the first fuel filter/primer is a tach that senses the 133 tooth flywheel ring gear. Is already connected into the wiring and wired up under the drivers dash and on into the center of the console…
