What have you done to your 5 ton this week?
hgun
342
Leechburg, PA
I got my horn fixed tonight it was either the horn button the rusty nut or the bad looking wire. My wife is really good at putting on those packard plugs. Here’s a question where does the wire that goes down the steering shaft come out at? I looked through the TM it shows the steering shaft but no horn wire. And the horn diagram shows the wheel parts and the box on the shaft but no long wire. I’m thinking it’s PFM. But don’t matter it didn’t need replacing thank goodness lol.
Valley Rock
Big wheeler cat peeler
587
Rogue Valley OR
M931A2
I insured it thru Hagerty yesterday for $298.
Never used them before, phone call was uncomplicated and fairly quick, although I don't believe they're actually insuring the truck I think they're the middleman, just like when Progressive uses Artisans insurance .
Matters none to me .
Also I put a receiver style hitch on the rear a while back I don't know if Iever mentioned it, now the truck can tow any trailer I own with it having a fifth wheel, pintle and standard receiver .
I found a receiver that had been removed from I think a newer dodge pickup .
It was too wide to to go on to the outside of the frame rails on my truck, but the receiver was bolted together, so I unbolted it, configured it to how I wanted (flipped the bottom receiver hole around) and bolted and welded it back together .
I am going to add some lateral reinforcements but just haven't got back to it yet .
hgun
342
Leechburg, PA
Hi Valley Rock. Do you know what year Dodge truck it was off of? I want to do the same thing my old deuce hitch won’t fit because of the lights. I would buy the hitch if I knew which one. Just curious thanks
Valley Rock
587
Rogue Valley OR
I do not, I tried to scratch the paint off a sticker on it, but all it said was "owning a modern dodge can be hazardous to your mental health"
It is a Torklift model, and I can tell you it took a fair amount of work to make it fit, alot of cutting, welding, reconfiguring and I'm still putting the lateral bracing on it, way more work than I thought, everything is jammed in a small space on these and in the way .
Removing the air lines to the meow defunct CTIS gave me moar uptravel
Now I need some carc paint if anyone has any lying around ... 😒20240622_114440_HDR.jpg20240622_114448_HDR.jpg20240622_114452.jpg20240622_114521_HDR.jpg20240622_114526_HDR.jpg
