Lock out hub question
Riggs
Winchester Va
I’m trying to understand the purpose of the lockout hub upgrade. I’ve searched the site but still have questions. I have a new to me and first time owner 1970’s M35a2 with PTO winch. It has an air lockout switch for what I believe is the front axle. Having said that, what’s the purpose of putting lockouts on front and rear if the air switch does that? Thanks in advance
cattlerepairman
3,463
NORTH (Canada)
In short: reduce wear and tear on the front part of the drive train. The axle shafts are permanently connected to the front wheel hubs. Even with 6x6 disengaged, the front wheels spin the axle shafts and the front drive shaft passively. This sucks power and causes wear on the assembly for no good reason. The lockout hubs stop that. The wheel hubs spin freely and the axle shafts and drive shaft sit still until you lock the hubs.
The air switch only connects the front drive shaft to the transfer case. It cannot help with the front wheels passively spinning the whole assembly.
The lockout hub on ONE side of the forward rear axle serves the same purpose; it causes only the rearmost axle to put power down, for increased "fuel efficiency" (LOL!) and perhaps, maybe a better turn radius. You can also get hung up on a speed hump or banana peel. IMHO, the rear lockout hub is a bit questionable, unless you do a lot of long-distance highway driving.
montaillou
845
W.WA
I put lockouts on the front mainly to improve fuel efficiency.
I have personally been in situations where lockouts on either back axle would've been very bad for me - unplanned like all the best accidents.
