I've been working on a crank no start issue with a M1078A1 that ran fine when shut off, but sat for a couple months. It has been stored indoors since and just cranks and doesn't even try to start. In following the troubleshooting in TM 9-2330-365-20-1, I get as far as e6 (is 24 vdc present on TL2
. I guess that's where the A1 differences catch up. Is there a TM for the A1? I have searched with no success.
In looking for that fuel solenoid, I found the attached pictured device, which appears to be some sort of solenoid. It is missing the nut, so I assume it may not be working. 24V is present in the connector. Is anyone familiar with what this device is? Thoughts on if it could cause the problem I'm seeing?
In reading this thread, I see that someone said the A1 has no fuel solenoid. So perhaps I need to move on down the list?
