M38 Frame Off Restoration
HoveringHMMWV
1,367
AL
This past summer, I told my wife that I would like another project. With a smirk, she immediately handed me a list of household chores that needed to be done. Joking aside, she truly understood what I meant and she placed a WTB ad on our club’s FB page. It didn’t take too long before I was inspecting a great candidate for restoration. The M38 even included a restored trailer. It was a non runner but I was told that it had recently although not very well. So, I loaded them on the trailer with the help of some friends, and thus began my new project.
I spent the first few months getting the M38 just to run and move, thus evaluating what would be needed for a resto. Finally began the disassembly shortly after Christmas. I am very grateful to my wife for letting me use her side of the garage! With all of the major components removed, I began with the frame.
Knowing that the paint was probably lead based, contamination and disposal were my primary concerns. I initially decided to use a liquid paint stripper. Initial tests were quite favorable but I quickly found that it was way too slow and very messy. I then opted for a needle scaler with plenty of plastic sheeting to catch the residue. And of course, protective clothing and a full face respirator were used.
I am now beginning to follow up with a die grinder fitted with a sanding pad. The frame has turned out to be in great shape with the only significant structural rust being at the battery box plate. I have also found a few “W” or “M” stamps under the paint. Ideas on their significance would be greatly appreciated.
More to follow in the days, weeks, months to come.
HoveringHMMWV
1,367
AL
More progress with the die grinder with abrasive pad or electric drill with wire wheel. Using a ”wet sand” method and low RPM’s to stop any airborne dust or particles. Drips, splatters, sprays are contained on plastic sheeting which is promptly disposed of. Will eventually follow up with a phosphoric acid treatment to convert any remaining spots before priming and painting.
HoveringHMMWV
1,367
AL
A minor milestone was reached today. The frame is finally ready for it’s first coat of primer. This was made possible after spending the week removing the last vestiges of old paint and grinding/blasting on any areas of rust. I had a local welder tack on a new right rear shock absorber bracket. The original was, in my option, structurally compromised. And today I was able to treat the entire frame in a metal treatment (sulfuric acid) in preparation for priming in a few days. Altogether, I‘m guessing that I have around 40 man-hours invested.
flyfishtrailer
1,108
Cool, CA
I have so wanted to find and restore an M38. They are my favorite of all the Jeep variants. I was able to restore an M100 that I hope to someday have the appropriate tow vehicle for. Following your restoration with a little bit of jealousy.
HoveringHMMWV
1,367
AL
Thank y’all for the comments. I knew this before starting, but it has to be a passion. If ever sold, there is no possible way that I could price it to make up for the parts and labor involved. I built model airplanes as a kid (both plastic and balsa). This is just a larger and more complicated version of that, takes much longer, and uses some different skill sets. It’s what I like doing.
HoveringHMMWV
1,367
AL
Yesterday, I treated the internal frame sections with Eastwood’s Internal Frame Coating. Today, I sprayed two coats of Rustoleum Rusty Metal Primer on the frame. It felt good to make some progress forward. On Wednesday, after the primer cures, I’ll be able to spray a couple coats of 2430. That’s when it’ll really feel like progress is being made.
HoveringHMMWV
1,367
AL
The weather was gorgeous today, so I used my engine hoist to move the frame outside. I was able to spray multiple coats of 2430 (original factory color) on both the under and top sides. For ease, I chose to just rattle can it. I purchased the GCI paint from Army Jeep Parts and it performed great. After letting it dry to the touch, I splurged and installed the axle-frame bumpers just so I could say “assembly has begun.” A total of 8 1/2 cans were used.
HoveringHMMWV
1,367
AL
Finished painting and installing the front bumper, lifting brackets, and lifting hooks. I had to add a spacer washer for each aft bracket bolt hole to keep them level on the bumper (not sure why). The M38 had rear lifting hooks installed on both the front and rear bumpers. I will eventually have to source the correct front lifting hooks for correctness.
HoveringHMMWV
1,367
AL
Got the leaf springs out today for restoration. Disassembled and began the process of cleaning up all of the old rust, crud, and paint.
I was almost done with the first set when I noticed a crack! Quickly found out that the leaf had been cracked for some time and finally failed with very little force on my part.
Notice the rusty portion was more than 9/10 of the thickness! So, this got my attention. How many more leafs are degraded? Since I had already decided that this would be a motor pool resto, for safety reasons I am now replacing all leaf springs with current US made sets. I do not want to risk a failure for me, a future grand kid, or a future steward of this vehicle.
Disappointed but comfortable with this decision.
HoveringHMMWV
1,367
AL
Began disassembling the rear axle for inspection and to replace worn components before clean up and paint. Found out that someone had incorrectly installed a diff bearing cap (see pic). So glad that I opened it up to take a peek for myself.
Also looks as if this diff was painted a few times after it’s discharge from military service.
HoveringHMMWV
1,367
AL
Had a very productive day and made a lot of progress on the rear diff. About half way done with stripping the old paint and crud. Should have time tomorrow to finish up that phase. Found a couple of interesting stamps that were hidden under the paint. Not sure what the symbol with P means. But I would surmise that the 12 1 50 is a build date for the axle unit. The bearing cones and races looked good and had no wear, pitting, or groves in them. New seals have been ordered and will be installed after prime and paint. I'll measure backlash and pinion bearing loading (?) before sealing it up.
HoveringHMMWV
1,367
AL
Finished cleaning up the exterior of the axle unit today. Will prime and paint next week. Has an interesting data tag riveted to the top side of the case. Will need to do more reading on this. Primary tools were a needle scaler followed up with a pneumatic angled die grinder along with PPE.
HoveringHMMWV
1,367
AL
Was finally able to put in a few days of work on the M38. The AL heat was been draining and I’ve only been able to work for just a few hours in the late morning. Stripped down the front diff. Cleaned and primed the individual components. Ordered new bearings and races. Will hopefully paint and reassemble in a few weeks. Also had my first injury. Accidents with power tools and wire wheels happen fast.
HoveringHMMWV
1,367
AL
Made more progress toward completing the front and rear diff/axle assemblies. All components are now cleaned/stripped and primed/repainted. Used some beautiful weather over the last few days to press in some new L/R threaded lugs and assemble 2 of 4 brake backing plates.
