Military Heaters, All Models, Non Vehicular
Guyfang
26,248
Burgkunstadt, Germany
This is The Thread, for all Military Heaters, all Models, Non Vehicular, to simplify finding them in the Technical Manual, Misc. TM's Forum. Each Post, below this one, will include a different Heater. As new Heaters are posted, this thread will be updated.
I would like to thank members @Milspec33 @Neophyte , @juanprado, @epitts and @Mullaney for their contributions.
Heater, Duct Type, Portable, 400,000 BTU, Gasoline Driven, Model BT 400-40, NSN: 4520-00-792-8257 & Model BT 400-40-1, NSN: 4520-00-930-9474
TM 5-4220-208-15
TM 5-4220-208-25P
Heater, Duct Type, M68, Gasoline, 25,000 BTU, Model VBM-250, NSN: 4520-001-7726
TM 5-4520-224-14
TM 5-4520-224-24P
Engine, Gasoline,
LO 5-2805-256-12
TM 5-2805-256-14
TM 5-2805-256-24P
Heater, Duct Type, Portable,HDU-36/E, 120,000 BTU, Model H82, NSN: 4520-01-254-8548
TM 5-4520-256-14
TM 5-4520-256-24P
Air Conditioner/Heater, Horizontal, 18,000 BTU, Model F18H-MPI, NSN 4120-01-327-1316
TM 9-4120-401-14
TM 9-4120-401-24P
Heater, Space,Radiant, Large (H-45) Model: Type I, NSN: 4520-01-354-1191 & Model Type II, NSN: 4520-01-329-3451
TM 9-4520-257-12
Army Space Heater (ASH), Electric Powered, Multi Fuel, 120,000 BTU, Model H120, NSN: 4520-01-367-2739 and Model H120-1, NSN: 4520-01-439-1682
TM 9-4520-258-14
TM 9-4520-258-24P
Improved Army Space Heater (IASH), Electric powered, Multi Fuel, 140,000 BTU, Model H140, NSN: 4520-01-477-0568
TM 9-4520-271-14
Large Capacity Field Heater (LCFH), 350,000 BTU, Diesel Driven, Diesel or Jet Fuel Fired
TM 9-4520-272-14&P
Heater, Water & Ration (HWR) NSN: 7310-01-387-1305
TM 10-7310-241-24P
Space Heater, Arctic (SHA) Multi Fuel, 15,000-25,000 BTU, NSN: 4520-01-444-2375
TM 10-4520-261-12&P
Space Heater, M1950 Yukon
TM 10-4500-200-13
Heater, Space, Model UH-68D, 60,000 BTU/HR, With Blower, NSN: 4520-00-114-1055
TM 5-4520-233-14
TM 5-4520-233-24P TM slightly damaged
Guyfang
26,248
Heater, Duct Type, M68, Gasoline, 25,000 BTU, ModelVBM-250,NSN: 4520-001-7726
TM 5-4520-224-14
TM 5-4520-224-24P
Engine, Gasoline,
LO 5-2805-256-12
TM 5-2805-256-14
TM 5-2805-256-24P
Guyfang
26,248
TM 9-4520-272-14&P
This TM was very large, and had to be broken up into 3 parts to upload. Simply down load all three parts and combine them with a good PDF program. I use PDF 24, because its easy on me Digital Dinosaur mind,
Guyfang
26,248
OPERATOR, ORGANIZATIONAL AND DIRECT SUPPORT MAINTENANCE MANUAL, INCLUDING REPAIR PARTS AND SPECIAL TOOLS LISTS HEATERS, SPACE: RADIANT TYPE, PORTABLE (TYPE I, MODEL M1941, SOLID FUEL) FSN 4520-257-4877 (TYPE II, MODEL M1941, LIQUID FUEL) FSN 4520-927-4214 (YUKON MODEL M1950, SOLID OR LIQUID FUEL) FSN 4520-287-3353 HEATERS, IMMERSION: LIQUID FUEL FIRED, FOR CORRUGATED CANS, (ALL MAKES AND MODELS) FSN 4540-266-6835 (PREWAY MODEL
447-2EX) FSN 4540-453-9140 FOR TANK TRAILER, (ALL MAKES AND MODELS) FSN 4540-266-6834
TM 10-4500-200-13
