5 ton crew build
CrappiePoint
115
33
Arkansas
Nice work CrappiePoint.
This thread also jutted some old memories lose.
Took some time to find some threads about it.
DaveP's sleeper cab with tanker trailer
Another one about Dave's truck
This is an adapted M820 with an old Peterbuilt sleeper, done by member DaveP. Tried to find any more information about it, but these are threads from around and well before 2010.
I was seriously thinking to do something like that here also, but a) I had an M51A2; too short for a sleeper, and b) the European rules on changes to trucks are so strong that it is close to impossible.
Rules here are basically NO to everything, and if Yes, you have to go for a special checking and bring a lot of documentation with you that this is really safe, build according to all rules etc etc.
I was lucky in 2012 with my dump to tractor conversion, both are existing trucks and I did not made serious changes to the frame. Now its even more problematic because the rebuild would be seen as a "new" vehicle and has to follow the rules for new vehicles, like double brake system, emission rules etc. .
WOW!!! That think looks AWESOME!!!
CrappiePoint
115
33
Arkansas
Photo dump !! It took a while to get that ?!$#* door mounted and sure it’s square in all 3 dimensions. But, after redoing it 2 times it’s on there for good. Also added a jump seat behind the pass seat. Sometimes we have 30 ppl in that truck so extra kid seating is a must!!! The A B C D & E pillars are solid. The next step is getting the seats all bolted in while the drivers side is still open. I started a YouTube channel and I will try to get a link on here.
CrappiePoint
115
33
Arkansas
Hey guys. It’s been a while but I finally got the doors set and welded in. I am very happy with the results. I will get the drivers jump seat in next? then skin and caps to basically make a roadster. After that we will get after the top.
th3v3rn
Utah
Looking good. Still waiting on hinges to mount the doors but hopefully this week.
What are your plans for the cab weather strips? I wondered if paying for NOS ones is worth it or just create something from scratch.
CrappiePoint
115
33
Arkansas
I’ll probably make some from channel or angle and add the rubber. I’ll start that in a week or two something tells me skinning the sides is going to be tricky!!
CrappiePoint
115
33
Arkansas
Sorry for the delay guys. Got the last of the seats installed, pull handles, and skins complete. I will finish the caps on top of the door jambs this evening. The next step will be cutting and stretching the top. I will also be beefing up the top for a roof rack. Thanks for following.
CrappiePoint
115
33
Arkansas
Hey guys sorry for the delay. Lots of other priorities and 1 tornado have gotten in the way. I took a day and got all of the doors squared up which involved building new stainless door pins after heating and beating the old ones out. It is easy to get the hinges bent in the press. But those doors are fricken heavy so make sure you get the measurements right. I have the top cut up and mounted. Tonight I’m getting the first “bar” cut to fit over the window s and tacked to the top front and back to set the distance and height. Once I get these two pieces in I can move quicker and fill in the spaces. But there is a bend in the bar where the cab tapers in so it’s a bit tricky. I’ll see you guys soon.
CrappiePoint
115
33
Arkansas
Pulled mine out of the garage because I wanted to get it out and get the dust off it. The roof, skins and seals are a pain. But air ride seats are amazing.
WOW!! Looking good!! Can’t wait to try the air ride!! But have to get longer battery cables to relocate them to the tool box.
CrappiePoint
115
33
Arkansas
Chang of plan. I used a 1x2 to set the door and window gaps. This will let me use the stock strips. Now to find replacement rubber for them. Your project is looking good!!
