Looking for MEP-003A and M116A2 stuff - bows, vinyl cover, suppression kit, etc.
1,161
Hey everybody
So, I've always said I didn't want a generator, as I felt my power was so reliable that I'd do more maintenance to a genset than I'd actually use it. But my power has been going out more frequently, and for longer periods in the last couple of years. And the giant storm a few months ago that wiped out Augusta and Asheville had originally been forecast to go right through Athens, Ga., where I live.
A friend of mine has a great setup with his shop and house running off an MEP-003A and I've decided to copy that. And that same friend scored me a great deal on a 003A with reasonable hours and an M116A2 trailer. The genset will need some maintenance to bring it back to my standards, and so will the trailer. No biggie.
Judging from the pictures below, you can tell some of the stuff I'll need.
  • A green vinyl M116A2 cover. This is the cover that goes all the way down to the trailer and has allowances for the wheelwells. Like this:
  • A full set of bows.
  • Extra jerry can mounts and the toolbox seen above. I will probably not restore the trailer to 100% correctness, as I'm probably going to add a larger fuel tank, civilian lights so I can pull it with my 4500 as well as Deuce, etc.
  • An NOS 10-pin trailer wiring connector. This one, the rubber end is rotting.
  • NOS data plates for the genset and the trailer. I already found an NOS id tag for the trailer, the one that has the VIN and such. I'm going to repaint the genset and the trailer and I'd love to replace all the data plates.
  • I think Eastern has NOS brake assemblies for the passenger side, does anyone has NOS drivers side units?
  • If it exists, I'd love to have an NOS gauge panel:
  • I'd love to have a noise suppression kit (ASK – Acoustic Suppression Kit) for this thing. It's going to be out under an awning by my shop and it'll only be 220' from my closest neighbor. If it runs for a day, I can see a neighbor getting whiny. I think the suppression kits for these are uncommon? I don't remember seeing many. I know I could make something, but I have zero extra time in my life. I'd rather just buy something and paint/reinsulate it.
    Like this: https://greenmountaingenerators.com/product/mep003a-sound-kit-ask-acoustic-suppression-kit/
When I get further into the restoration of the units this winter, I'll probably need more but this is what I know of for now.
Thanks
C
Guyfang
26,861
Burgkunstadt, Germany
I know I would be talking to @Ray70 about his spin on fuel filter upgrade if that set was mine.
The ASK kit has a serious trade off to it. Yes it makes that gen set much easier to live with. But it make maintenance more of a pita. It also can attract mice like a magnet.
Looking forward to you working on the Gen set. If taken care of, that set is bomb proof.
1,161
Ok, so far I have managed to score:
A new dataplate for the trailer
New trailer wiring connector
A spare wheel
My gooseneck trailer uses the same tires and I'm about to replace them, I'll keep the best 3 and mount them on these wheels
Tinstar's NOS gauge panel
Diaper pin clips for the d-rings
NOS gas cap for the generator
New oil pressure shutdown switch
New voltmeter
I'm still looking for the correct bows and vinyl cover.
I'd love to find any NOS dataplates for the generator itself
Thanks!
1,161
I am still looking for all of the stuff above:
I need M116A2 data plates
ALL of the MEP-003A data plates (only interested in NOS)
M116A2 bows and cover
I'd buy an Acoustical Suppression Kit in any condition (doesn't have to be NOS)
So, I'm slowly making headway on this thing. I replaced the hacked up oil drain hose with the correct unit.
This was all hacked up and didn't have the fitting on the left to attach to the deadhead fitting
I received Tinstar's NOS panel (thanks again!) and installed an NOS voltmeter in it:
I also have civilian LED taillights, a civvy 7 pin connector and some other stuff.
As soon as the filters and oil show up, I'm going to go through all of the fuel pumps, do all the filters, clean out the fuel tank, etc.
Anyone have any of those parts on my list?
1,161
i have bows in OKlahoma
Excellent!
I know they'd have to go truck freight, so let me see if I can find a friend going to or coming from OK soon.
Thanks
1,161
bump
I'm still looking for:
NOS M116A2 data plates (I have the one you stamp the trailer VIN in, I need the others (weight and center of gravity plate, the genset data plate, etc.)
Also, there is an SS user in Oklahoma who has the bows, but we need to find a way to get them to me. Transport thread here: https://steelsoldiers.com/threads/t...-a-couple-hundred-miles-of-atlanta-ga.223954/
Thanks
