Central FL M1031 project
biscuitwhistler37
1,209
Michigan
Ugh..... I liked the eye bolt in the head stud hole idea mentioned above, until I saw what angles the eye bolts would be at.
I wouldn't think a headless engine would be heavy enough to crush a pan, especially if you used a 4"-6" wide strap, but can't say for sure.
Carc might be on to it, drop the pan and pump, (assuming the oil pump is lower than the bottom of the block), wrap a strap basket style and lift. Most effort, least likely to fail.
Either way, ugh.....
CARC686
639
Las Cruces, New Mexico
The critical part being to reassemble it out of the truck and install it complete on chains with the cherry picker, because I've no faith in the ability to stay on axis trying to lower the block back into the mounts wearing a diaper made out of a tow strap. There's no telling how the wraps will shift when they come under load. Even in the unlikely event that it was to line right back up, the straps could migrate into pinch points. An engine stand is a pretty important piece of the puzzle.
deank
556
Inverness, Florida
Well, today was productive. Block is now out and on the engine stand. Ready for cleaning and reassembly.
This time while I have it out, I am going to remove the starter solenoid wire from the engine harness and run it across the cab firewall with other wiring, then down to the starter.
nyoffroad
720
Rochester NY
You pulled the engine with the radiator in place? Personally, I would have pulled the radiator and given serious thought to removing the core support, it's not that many bolts and you wouldn't have to lift the engine so high. In the past I've pulled the engine and tranny out the front, that was HEAVY! I usually use a couple bolts near the water pump or the lift ring .
deank
556
Inverness, Florida
Today I was finally able to get back in the shop. I had a rotator cuff repair on 22 April. Still technically in a sling. I had my grandson and one of his mechanically inclined friends come over today to help reassemble the engine. Good progress was made and they did a really good job of listening, reading, and following instructions to be my hands today.
My school recently reassigned some parking spaces. I got my old sign and modified it. I will put in on a light pole in a grassy area near my classroom for the days I drive the M1031 to school.
