M200A1
McKeelo
57
Upland, CA
Hey Guy,
I did download the TM and look this because what is missing is the handle. So I thought if I could find the parts in the TM maybe I could fabricate something that would work. After reading through the TM I came to the conclusion that it might just be easier to replace the whole thing. Here’s a couple pictures of it.
Guyfang
26,262
Burgkunstadt, Germany
This is the old style jack leg. Its certainly repairable. Parts availability is the problem. The new style, is not supposed to be repairable, but I have done it a few times.
McKeelo
57
Upland, CA
Ok, thanks for the info.
So are you suggesting I continue to look and ask for parts or will I have a better chance of acquiring the whole jack?
Guyfang
26,262
Well, this is a parts wanted thread, so let it do its thing. parts or the whole jack. If you are someone who can use a metal lathe, you could make the crank arm, but if you are like me, look for the part/jack leg. The new style are not so easy to find. Lets see what happens.
