Brad
- 26
- 28
- Bolivar, Pa
This is the electric fuel pump that has been on this truck since I can remember, 20 yrs or more?
Also a look at the screen filter in it. This is the M135 that was running fine and then started romping and lurching at times. We changed the other filter and even removed and cleaned the carb, which looked fine as far as I could tell. Even though this filter has probably at least 50% open, do you think it could be the trouble?
