So the MTVR adventure begins
aw113sgte
1,389
La Crosse, WI
Changed all the diff fluids today, front one had a sliver but looks like its a piece of the NPT threads on the fill/drain. Middle may have had a tinyyyy bit of water but scoping the diff internals showed no rust.
Got the new batteries and the wallet is hurting (6-700 a piece) from the AGMs but with my experience with flooded lead acid in my MTV I wanted the increased CCA of AGM (although the C12 starts way faster than the C7 so maybe it wouldn't be an issue.)
Touched a plug on the ABS module (or maybe TC) and it just crumbled like a dried out cookie. I assume every other connector is the same. Nice thing is, they are just seals so the pins can still be connected.
Found 2 ball joint seals that are cracked. Not looking forward to that as the replacement process is very involved.
The big surprise....Saw a castle nut backed off on the "tie rod". The taper was also loose. Had this nut fallen off, the rear wheel would have turned violently to left or right. Glad I caught it. Looks like when a service was done, the nut wasn't tightened and as such the cotter pin wasn't installed.
aw113sgte
1,389
La Crosse, WI
Have been doing a lot of boring stuff lately, pulling stock heater for future AC install, lining floor with vibration damping (the good, pricey stuff from resonix). Got the floormatt material from the same supplier to the military (supposedly-it does match the floor matt of my MTV). Installed the keyed door handles. Put on the sides and cover to let the kids at my sons school play around in it. (The stock 12v converter powered the fridge filled with ice cream without issue).
b10bcea3-50a1-4af1-8ce1-9202a86279ca.jpg20250515_132036.jpg08ce3d79-1359-4a82-b862-c2ac04598d1b.jpg20250514_101215.jpg20250515_131328.jpg20250515_125908.jpg20250515_132524.jpg
aw113sgte
1,389
La Crosse, WI
Original heater panel was in bad shape, cracked. I also didn't get a new panel in my AC kit and they seem to be unobtainable on their own. 3D printed a new one with transparent letters so the LED backlight would still work - although it doesn't end up lighting it very well. Old fan switch was a bit rough so replaced that as well, and put in a switch for the future AC install.
Few pictures of the mounting methods for the new seats. The aluminum bar on the rear bulkhead is tied into the truck with 8 bolts across it's length. Each seat has 4 bolts. The seat bottoms fold down and can rest on the storage box. The drivers seat had to be moved over a few inches to fit the 4 across.
aw113sgte
1,389
La Crosse, WI
If you have a failed fuel sender, this one works. It doesn't have the low fuel light capability but other than that, good to go. You do have to wire it in. Isspro, part number RA9521-ISS-LP, $114
Connect to red and black wires. Blue is for the low fuel light. Sender wires are non polarized so you can connect either way.
You do have to slide the tank out to remove the sender.
FYI, I did check for the original part number but the manufacturers won't sell it and ATAP requires an order of 5 with a long wait time. Isspro used to make the OEM ones but no longer do.
aw113sgte
1,389
La Crosse, WI
Haven't spent a ton of time on the truck lately with the kids being out of school for the summer and going on lots of trips with the FMTV camper. Did get the cab taken apart a bit to get all the needed measurements and have modeled up the design a little. Going with a cabover setup, with an accordion seal to the rear habitat. With the cab roof and rear panel gone, there will be a large pass through area. Planning on putting 2 beds in the cab over. That structure will be mounted to the turret legs (that will be cut down a bit). The turret legs will be braced even more to help with rollover protection. I am currently thinking of building the cabover to be a self contained "survival pod". If I built it strong enough to support the truck in a rollover it would make it way too top heavy - like 4"x4"x0.25" steel members (making a rollover more likely). So instead the frame will be tubular steel (thinking 2"x2"x0.1" but that may change a little) and have breakaway bolts so it separates in the even of enough load. Will have 6 point belt system for the beds.
I think I will be removing the front bed bulkhead for more room. The exhaust stack will be a bit shorter and I'll have it exhaust sideways - out and away from the habitat. The air intake will also be shortened (I have the cap attached directly to the filter inlet for now). I do need to have the space between the cab rear wall and the habitat enough so I can shimmy back there to service the vents and valves. I may move the transmission fill location. I suppose I could move all the stuff back there if needed.
