tjf1980
- 1
- 1
- Olathe, KS
Long story short, I sold my M1009 to a guy a few years ago. He was in way over his head with a military diesel and I bought it back last fall. He had replaced the alts, with the wrong ones and bang. Ruined two brand new alts.
I rebuilt them using the correct parts and cases. Alt 1 is good and charging.
My current issue is none of my idiot lights on left side of the inst cluster are working. Nothing over there lights up when key turned to run or while running.
Fuses all good and power to both sides. Instrument cluster circuit and connector are good. Bulbs all good.
Alt 2 isn't charging but I assume it's because the gen light isn't working?
Possible coincidence? Maybe the 4x4 switch is bad and on top of that there's still something wrong with the alt circuits? Should the oil pressure light come on when key is on?
Any common item that would cause all 4 of those lights to all not work? Anything else common that fails when the alts go boom? Fusable links? Relays?
What would be the next logical things to check?
Any help is appreciated. Thanks!
