need starting electrical guidance please
diggerdave65
north hero vt
Hi all-- after sitting about a year i cant get my M1008 to start. Here is where im at ( I am not very good at reading F-1 or F-3 in the TM so please bear with me)
I ran the truck for years and never had a problem.
It was converted to 12v by the corp of Engineers before i got it. They added a dash mounted solar battery maintainer and Dash mounted "air conditioning "... (also known as an electric fan...)
I put in the dog head
Due to life it sat for a year in a covered dry garage
No hints of mice nesting anywhere
I tried starting it but batteries were mostly dead
So I got 2 new batteries and new plugs
I cleaned the bus bars and the contacts on black diamond and the solenoid
With the key off I get 12.46v at both sides of the black diamond and the terminal it feeds on the solenoid.
I get 12 V at the dog head.
I get 0 at the one side of fuse #20 ( in the TM its #17 engine control fuse)
With the key on the wait light comes on intermittanly ( seems to be controlled by fuse #20)
I only get 1.6v at the diamond and solenoid and around 1.14v at the dog head.
I have not chased the 4 fuseable links that disappear down a loom towards the transmission.
Any thoughts on where to go from here?
Appreciate any input. Happy Memorial Day weekend to all that have served this great country of ours. dave
diggerdave65
north hero vt
i should add that it does not allow me to even turn over the engine at this point. I did try many many times to start it with the not fully charged batteries and wonder if i have since burned something out that wont let me turn it over. Hindsight is 20/20.....
diggerdave65
north hero vt
update: with the key in the run position IF and only IF the wait light comes on I am getting 11.68 volts at the black diamond and the solenoid the black diamond feeds. I also get 11.68 volts at the dog head.
Once the wait light goes out you turn the key to start it and i get nothing.
Im not sure how the wait light works because it does not come on every time you turn the key on. It may come on once out of 20 tries. (wondering if my ignition switch or any related parts be worn out?)
So just for giggles i put the original under dash relay back in with the same results. I tried another dog head solenoid that i borrowed from a working mower - same results as above.
Also used a good ST85 solenoid from a plow and swapped it on the fire wall - same results.
Anyone have any thoughts? Much appreciated. thanks dave
Tinstar
2,250
Edmond, Oklahoma
Are the battery cables and other starter wiring original?
I discovered the hard way that while they look fine on the outside, the corrosion is rampant on the inside, under the sheathing, and providing extreme voltage resistance.
Same for the fusable links.
Don’t jump around to different places.
Start at the batteries, making sure their charge is topped off, and work from there.
Sounds like you have multiple issues and possibly 12v conversion gremlins.
