mbfd592
- 19
- 3
- Long Island New York
I replaced my boots, axle seals, pinion seals, and wheel bearings on my M35. Took it for a test ride and the driver side hub was 130 degrees compared to the passenger side being 90 degrees. Took the driver side apart to look everything over. Everything looked ok. Re packed the outer bearing (grease that pushed out was a little on the dark side). Re torqued the spindle nuts (50 lbs and a quarter turn back). Put the wheel back on and took it for a test ride. Temp on the driver side was 140 degrees compared to 98 on the passenger side. All the rears were around 115 degrees. When I repacked the outer bearing it didn’t feel like it was spinning right. I thought it was just from all the grease on my hands. I feel like I might have gotten a bad bearing or is there something else I can look for? I would appreciate any suggestions on what to look for. Thank you
