Model JHAA/C6V1 - 6000btu AC not cooling.
Max Bladwin
Michigan
Hello,
I could use some help with my AC. Its my 1st time using it. The ac compressor does not kick on. I have the control plan set to "ac", the thermostat set to "decrease" and the fan switch set to low. When it on all i hear is the fan amd no compressor. I checked the breaker and the 2 reset buttons on the back of the unit and nothing seems wrong.
Any ideas?
NDT
7,286
Camp Wood/LC, TX
Does it have refrigerant in it? Usually these get drained prior to going to drmo. You might be able to jump out pressure switches to see if the compressor is good.
