Polaris MRZR-D4 Parts List
Lawdog734
180
Colbert, GA
I decided to put together a spreadsheet of the various parts that everyone has been chattering about in the "Polaris MRZR-D4" thread, so I could keep it all in one space versus searching through what at this point is a 14-page thread. I'll try to keep it updated as we get more contributions regarding what works and doesn't work - big thanks to @publicenema from the great white north for helping search Polaris part numbers that are specific to the MRZR's. While what I have here is specifically for the diesel MRZR, I'm sure there may be some cross-compatibility with the gas models as well, I just don't know where.
Anything with a question mark(?) behind it is something that is unknown as I haven't been able to confirm a part number via Google or hasn't been verified to fit by one of us. If someone verifies that it does indeed fit, I'll remove the question mark.
If anyone has any parts that they've found worked for them - send me a chat and I'll be sure to add it to the list.
POLARIS MRZR-D4 PARTS LIST
BODY/SUSPENSION/STEERING​
POLARIS PART NUMBER​
DESCRIPTION​
ALTERNATIVE PART NUMBER​
7044788Walker-Evans Front ShockWalker-Evans #A-SH-922-32-637
7044790Walker-Evans Rear ShockWalker-Evans #A-SH-922-32-835
4014042Throttle PedalAvailable on Amazon
DWT MOAPA Tires - 28x10x14 (Stock for Gasser)DWT #UT-281
BFG Mud Terrain T/A KM3 28x10x14
(Stock for Diesel)
86699331724 (Amazon)
Floor Drain Plugs (x4)
CPOWACE 709046759872 (Amazon)
5412012Steering Rack Boot - Driver's SidePlenty of aftermarket alternatives
5412013Steering Rack Boot - Passenger SidePlenty of aftermarket alternatives
1333799Rear Axle (L/R Interchangeable)Polaris XP1000 axle - recommend a heavy-duty axle like Rhino 2.0
Cobra Axles in Houston, TX also has HD axles to spec for the MRZR-D4
GSP XTV Axle - Part #4107072
5415700Shifter Boot
ENGINE/TRANS/BRAKES​
DESCRIPTION​
Brake Fluid - DOT4
3040038Oil FilterNapa 1083
Oil - 15W40 - 3qts
Polaris Demand Drive FluidFront Gear Case Oil - 8.5oz
Polaris AGL FluidTransmission Fluid - 44oz
7082178Air FilterNapa 6489
Batteries -
ETX30L0E/30AH/400 CCA/12V - QTY, 2
Battery Cutoff - Eaton's Bussmann 200A/48VDC187200P-03-1
2521460Fuel FilterDonaldson P551099?
2521087Fuel/Water Separator
2208933 (x2)Front Brake PadsAny for RZR900 Series?
2208936 (x2)Rear Brake PadsAny for RZR900 Series?
1911982Brake Master CylinderQuad Logic 100-1187-2 (Amazon)
3211225Drive Belt
3235168Front Differential Cover
1333792Front Differential (Complete)
Clutch Cover Screws - M6x35 Fillister HeadQuad Logic B078RQBMR2 (set) (Amazon)
1323443ASM Drive Clutch
1323444ASM Driven Clutch
Clutch Kit - Complete w/ Drive & Driven Clutches w/ beltDura-Clutch , Part 15-580 per GCElevator
263136CVT Clutch Cover
3023106Alternator
1023088-329?Alternator Belt Cover (Original/Metal)
1023899?Alternator Belt Cover (Later/Plastic)
3040406Turbo Assembly w/ Wastegate
7082139Gear Selector/Shift Cable
StarterJ&N Electric 410-24210
Accessory Items​
DESCRIPTION​
Hi-Lift JackHi-Lift #UTV-424
Hi-Lift Jack MountsHi-Lift #TM-700
2879493Half Windshield
L-Track (Cargo) FittingsCheck US Cargo Control website
Rear View Mirror (Mount Incorrect, but mirror is)ISSYAUTO FVTMI019-FBA (Amazon)
Baja Designs Squadron Pro IR Light (Correct for MRZR)Baja Designs Part 497073
Blank 2-Position Light SwitchMarquardt # 3251.0058
Molle Panel Roof - ATS TacticalBy Request - Contact them
Miscellaneous Tools​
DESCRIPTION​
1023846Drive Belt Changing ToolPeatovie Mekar-001 (Amazon)
robberard
Patton, PA
Got an addition to consider.
Rear axels are interchangeable right or left. Found a very good and affordable replacement at Summit Racing for $160.00 each.
GSP XTV Axel #4107072
www.gspxtv.com
Replaced both of mine and no issues, other than removing old axels, that's the hard part.
