- 1,555
- 1,805
- 113
- Puget Sound, WA
I'm calculating 9.6 MPG in my M1165I’m serious. I get 8 mpg
If they know, they knowWhen I had my M1009 I was mortified if someone thought I painted a K5 in camo - "It came that way from the factory!"
I'd be equally mortified if someone thought my 1165 was one of those SUV conversion kits...
"They park them all over on the base, and there's no keys, so..."
Ironically, I think I could easily do just that. Several in the DRMO lot start right up. I keep mine looking like it's still on active duty, and have never even gotten some side-eye driving it out the gate.
I get about the same mileage. M1123, turbo engine and 40's shoesI found on my M1123 the throttle return spring at the end of the pull cable was stretched, replaced it and went from 1050 rpms to 700rpms at idle. That made a big difference, then fixed my Cadillac valve, thermostat and Time Delay Module. That gave me a huge bump... Went from 12 to 14.5. I know it's a 4 speed, but look into that it may help more than you think.
I'm serious I get 13... GENERALLY at the time I fill it up I am putting about 17 gallons in almost EVERY time.I’m serious. I get 8 mpg
I'm running with the 2 wire connector disconnected so the fan is engaged at all times.I found on my M1123 the throttle return spring at the end of the pull cable was stretched, replaced it and went from 1050 rpms to 700rpms at idle. That made a big difference, then fixed my Cadillac valve, thermostat and Time Delay Module. That gave me a huge bump... Went from 12 to 14.5. I know it's a 4 speed, but look into that it may help more than you think.
My 69 442 with a 455 in it (the original 400 gave up the ghost long before I got it.) With TH400 and 3.23 gears... Got a wee bit better mileage than this truck.@thoner7 if you want worser then find one of these huge "fat-and-long brick" usa 'fashionable' cars from <1972, some people joking (but these 8+litre engine with massive carburetor(s) to match..were very much for real) say that as fast as the horizontal speedometer is going to the right the fuel needle is going equally as fast to the left!
I have the geared fan drive, but thank you.I found on my M1123 the throttle return spring at the end of the pull cable was stretched, replaced it and went from 1050 rpms to 700rpms at idle. That made a big difference, then fixed my Cadillac valve, thermostat and Time Delay Module. That gave me a huge bump... Went from 12 to 14.5. I know it's a 4 speed, but look into that it may help more than you think.
I'm a fan of Series 2 109" Rovers... and Defender 90s... But specifically the Military issue Defenders...@KKroger this is unrelated but considering that both humvee and old landrover share a bit of common trait with regarding to going far offroad..I'll give you this story my aunt told me by email a few years ago;
By the way, many years ago when I was working in Montreal, our IBM rep
drove a Landrover, The company thought he should be driving a more
conventional vehicle but his clients loved it. Well anyway, he was out
somewhere (I forget where, but it does not mater) and saw something
interesting so he drove in to get a better look. There was not a no
trespassing sign. The police had to walk in to tell him he could not be
there and there was no sign because no one had ever been able to get in.
