wreini
- 3
- 3
- Charlotte NC
Hello, I just put on a new rebuilt injector pump because of a hard hot start issue I was having. New pump went in no problem, I aligned the timing marks to the timing cover. and it started right up and idled great. the problem I'm having is that it spits out a ton of black smoke now when I floor it. not just a puff. more like a quarter mile long haze. has pretty good response and it will even speed on the highway now. Smoke goes away once I make it up to speed. only appears under load. It did not smoke at all with the old pump.
I've tried to correct it by advancing the timing about 1/8th of an inch past the mark and several increments in between. It seemed to help a bit. but without putting some weight into it it wont go any further and I don't want to cause another problem by going too far. I've also turned down the fuel screw in the pump about 1/8 of a turn.
I have an electric lift pump installed, all fuel filters and air filter are new. I'm hoping someone can point me in a direction and I'm just having a moment. I'm supposed to drive it out to Colorado next week for a camping trip. All I've done to test timing is push in the advance. it will slow down a bit but doesn't stumble like i've read online.
Thanks,
Thanks,
