Terex 51-19M Telehandler Boom Problem
tmuenster
111
31
TN
I am having an issue with my Terex 51-19M telehandler boom. The boom will not go back down. I’ve checked the fuel to see if it was spiked with Viagra but its clean. :) Seriously, the machine runs and moves just fine except for the issue with the boom. Any chance someone could provide advice on how to safely lower the boom manually so I can get the machine in for service?
tmuenster
111
31
TN
I did replace all the smaller fuses, which I think included the F2 location. I am not sure about the F24 location.
1664929872581.jpeg The Emergency button is not depressed and I can start the machine just fine.
20,787
I rummaged a few books that I have.
Specifically in the Shop Manual on the 19-MD model, Fuses F1 F15 F17 and Relays R1 R7 control the Boom Lowering function.
Here are the books that I have.
Page 288 in the shop manual is trouble shooting for lowering the boom. (in ShopManual 03, Printed Page #282)
Sorry I had to bust up the book, but the site says at 40mb, the file was too large.
OBX
380
Moyock, NC
anyone have any questions on these. I built alot of them ,will help anyway i can
Help, please!
Same problem. Boom up no problem, boom won’t lower nor extend. Overload red light on while no load at all.
Otherwise, starts, and runs fine. Boom will bleed down and lower if left overnight due to very slow leak at valve block on base of boom cylinder.
Also, this valve behind cab has missing wiring connector. Could that be source of boom control problem?IMG_6022.jpegIMG_6021.jpeg
