Military Vehicle, Recovery Vehicle, Full-Tracked: Medium, M88A1, (NSN 2350-00-122-6826)
Guyfang
26,822
Burgkunstadt, Germany
Any information printed in Red, is not allowed to be posted in the forum, due to the TM Classification, or simply not to be found.
Member @155mm Last ride in the Army,
Guyfang
26,822
LO 9-2350-256-12, dated 1986 wc#1
LUBRICATION ORDER FOR RECOVERY VEHICLE, FULL-TRACKED, MEDIUM, M88A1, (2350-00-1 22-6826)
TM 9-2350-256-10-HR, dated 1979
HAND RECEIPT MANUAL FOR RECOVERY VEHICLE, FULL-TRACKED, MEDIUM, M88A1, (2350-00-1 22-6826)
TM 9-2350-256-10 dated, 1998 wc#1
Operators Manual, Recovery Vehicle, Full-Tracked: Medium, M88A1, (NSN 2350-00-122-6826)
TM 9-2350-256-20, dated 1996 wc#1
UNIT MAINTENANCE MANUAL, RECOVERY VEHICLE, FULL-TRACKED: MEDIUM, M88A1 (NSN 2350-00-122-6826)
TM 9-2350-256-24P-1, dated 1992 wc#2
UNIT, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST
(INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS) FOR RECOVERY VEHICLE, FULL TRACKED; MEDIUM M88A1 (NSN 2350-00-122-6826)
TM 9-2350-256-24P-2 dated 1992 wc#2
TM 9-2350-256-34-1, dated 1977 wc#8
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL, FOR RECOVERY VEHICLE, FULL TRACKED; MEDIUM M88A1 (NSN 2350-00-122-6826)
TM 9-2350-256-34-2, dated 1979 wc#7
TM 9-2350-256-PCL, dated 1990
COMBAT VEHICLE, PRE-COMBAT CHECKLIST FOR: RECOVERY VEHICLE, FULL TRACKED, MEDIUM, M88A1
(2350-00-122-6826)
TM 9-2350-242-ESC
Equipment Serviceability Criteria, CHECKLIST FOR: RECOVERY VEHICLE, FULL TRACKED, MEDIUM, M88A1
(2350-00-122-6826)
Guyfang
26,822
TM 9-2815-220-34 dated 1975 wc#5
ENGINE TECHNICAL MANUALS: DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL FOR ENGlNE WITH CONTAINER: TURBO SUPERCHARGED, DIESEL, FUEL INJECTION, 90-DEGREE “V” TYPE, AIR-COOLED, 12 - CYLINDER, ASSEMBLY; MODELS AVDS-1790-2C, 2815-00-410-1203 AND AVDS-1790-2D
2815-00-410-1204
TM 9-2815-220-34P dated 1993
DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LISTS
2815-00-410-1204
Guyfang
26,822
TM 9-2520-215-34 dated 2002
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE, CROSS-DRIVE, TRANSMISSION ASSEMBLY
TM 9-2520-215-34P dated 2002
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST, CROSS--DRIVE TRANSMISSION ASSEMBLY
Guyfang
26,822
TM 9-2990-205-34&P dated 1984 WC#3
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST), T U R B O S U P E R C H A R G E R, S C H W I T Z E R
M O D E L, 5 H D R
NSN 2950-01-432-0369 [12366708-1]
NSN 2950-01-434-3229 [12366708-2]
NSN 2950-00-397-3384 [11668377-1]
NSN 2950-01-167-1700 [187727]
TM 9-2990-206-34&P dated 1980 wc#2
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST), T U R B O S U P E R C H A R G E R, AlRESEARCH
MODEL, T18C01 NSN 2950-01-048-8870 [11669107-1],
AND 2950-01-167-1699 [466392-1]
Guyfang
26,822
TM 9-2910-212-34&P dated 1984
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST), PUMP, FUEL METERING AND DISTRIBUTING, AMERICAN BOSCH MODEL PSB- 12BT, NSN 2910-01-073-0124
TM 9-2910-213-34&P
Direct Support and General Support Maintenance Manual (Including
Repair Parts List): Pump, Fuel, Engine, Assembly, 8725131, 8725282,
8725283,’ 10882763 and 10882763-1 (Viking Model FV492
Guyfang
26,822
TM 9-2920-232-34&P dated 2005
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL, [INCLUDING REPAIR PARTS AND SPECIAL TOOLS LISTS] STARTER, ENGINE, ELECTRICAL, ASSEMBLY, DELCO-REMY-GMC
1109972 (2920-00-973-1557)
1990272 (2920-01-139-3722)
TM 9-2920-225-34 dated 1981
TECHNICAL MANUAL, MAINTENANCE, DIRECT AND GENERAL SUPPORT LEVEL, GENERATOR ASSEMBLY
PRESTOLITE MODEL AMA-5102UT,
NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AC,
LEECE-NEVILLE MODEL 3002AD,
LEECE-NEVILLE MODEL 3002AE,
LEECE-NEVILLE MODEL 5504AA,
NSN 2920-00-475-1446
LEECE-NEVILLE MODEL 5504AB,
LEECE-NEVILLE MODEL 2184AC,
NSN 2920-00-782-1955
LEECE-NEVILLE MODEL 5300GP,
NSN 2920-00-818-8635
TM 9-2920-225-34P dated 1974
TM 9-2920-224-34&P dated 1986
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT, MAINTENANCE MANUAL [INCLUDING REPAIR PARTS AND SPECIAL TOOLS LISTS], G E N E R A T O R A S S E M B L Y , E N G I N E ( 3 0 0 A M P )
8 7 1 7 4 2 1 ( 2 9 2 0 - 0 0 - 7 9 5 - 6 6 2 7 )
1 0 8 8 9 7 1 3 ( 2 9 2 0 - 0 0 - 8 3 0 - 6 6 6 0 )
1 1 6 4 2 8 9 8 ( 2 9 2 0 - 0 0 - 1 6 9 - 5 7 1 5 )
Guyfang
26,822
TM 9-2815-221-34&P dated 1985
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST), Engine, Diesel, Industerial Type, Model (DJEME) NSN 2815-01- 175-7342, Model (DJBMA) (NSN 2815-00-615-8740
Guyfang
26,822
TM 9-4910-571-12&P dated 1984
TECHNICAL MANUAL, OPERATOR'S AND ORGANIZATIONAL MAINTENANCE MANUAL, INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST , SIMPLIFIED TEST EQUIPMENT FOR INTERNAL COMBUSTION ENGINES
( NSN 4910-00-124-2554
Guyfang
26,822
TM 9-2540-205-24&P dated 1992
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR Heaters, Vehicular Compartment, for:
STEWART-WARNER
1056OC24 (NSN 2540-01-063-0691)
10560M (NSN 2540-01-071-0651)
10560M24B1 (NSN 2540-01-169-5159)
10560G (NSN 25404)1-262-6013)
HUPP
MF510B (NSN 2540-01-071-0652)
MF510C, MF60B-24V (NSN 2540-01-162-3834)
MF60A-24V (NSN 2540-00-930-8838
ESPAR
V7S (NSN 2540-01-114-7688
Guyfang
26,822
TM 9-5130-338-12&P dated 1997
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR WRENCH, IMPACT, HYDRAULIC, MODEL IW-12-140T, (PN 12322630) ,(NSN:5130-00-790-2284)
TM 9-5130-338-13&P dated 1961 wc#1
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR WRENCH, IMPACT, HYDRAULIC, (BOWEN-McLAUGHIN-YORK, MODEL BML15436)
NSN: 5130-790-2284
