Military Vehicle, Recovery Vehicle, Full-Tracked: Medium, M88A2, (NSN 2350-01-390-4683)
Guyfang
27,263
Burgkunstadt, Germany
Work in progress
Guyfang
27,263
TM 9-2815-247-34 dated 2000
DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL FOR ENGINE WITH CONTAINER:
TURBOSUPERCHARGED, DIESEL, FUEL INJECTION, 90–DEGREE “V” TYPE, AIR–COOLED, 12–CYLINDER,
ASSEMBLY; MODEL AVDS–1790–8CR (2815–01–414–6821)
TM 9-2815-247-34P dated 2000
DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LISTS
(INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS) FOR ENGINE WITH CONTAINER: TURBOSUPERCHARGED, OIL–COOLED GENERATOR, DIESEL, FUEL INJECTION, 90–DEGREE “V” TYPE, AIR–COOLED, 12–CYLINDER, ASSEMBLY: MODEL AVDS–1790–8CR
Guyfang
27,263
TM 9-2520-215-34
TECHNICAL MANUAL DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE
CROSS--DRIVE TRANSMISSION ASSEMBLY (11649999) (MODEL XT—1410—4)
COMPOSED OF: CENTER SECTION ASSEMBLY W/CONTAINER (2520--00--140--7526)
OUTPUT REDUCTION, LEFT—HAND ASSEMBLY W/CONTAINER (2520--00--896--9020)
OUTPUT REDUCTION, RIGHT—HAND ASSEMBLY W/CONTAINER (2520--00--896--9021)
CROSS--DRIVE TRANSMISSION ASSEMBLY (12366414) (MODEL XT—1410—5A)
COMPOSED OF: CENTER SECTION ASSEMBLY W/CONTAINER (12365775)
OUTPUT REDUCTION, LEFT—HAND ASSEMBLY W/CONTAINER (12365777)
OUTPUT REDUCTION, RIGHT—HAND ASSEMBLY W/CONTAINER (12365778
TM 9-2520-215-34P
(INCLUDING DEPOT MAINTENANCE ALLOWANCES) CROSS--DRIVE TRANSMISSION ASSEMBLY
TM 9-2990-205-34&P dated 1984 WC#3
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST), T U R B O S U P E R C H A R G E R, S C H W I T Z E R
M O D E L, 5 H D R
NSN 2950-01-432-0369 [12366708-1]
NSN 2950-01-434-3229 [12366708-2]
NSN 2950-00-397-3384 [11668377-1]
NSN 2950-01-167-1700 [187727]
Guyfang
27,263
TM 9-2920-232-34&P dated 2005
DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL (Including Direct Support, General
Support, and Depot Maintenance Repair Parts and Special Tools Lists)
STARTER, ENGINE, ELECTRICAL, ASSEMBLY DELCO--REMY--GMC
1109972 (2920--00--973--1557)
1990272 (2920--01--139--3722)
TM 9-2920-225-34 dated 2005
DIRECT AND GENERAL SUPPORT LEVEL GENERATOR ASSEMBLY
PRESTOLITE MODEL AMA-5102UT,
NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AC,
LEECE-NEVILLE MODEL 3002AD,
LEECE-NEVILLE MODEL 3002AE,
LEECE-NEVILLE MODEL 5504AA,
NSN 2920-00-475-1446
LEECE-NEVILLE MODEL 5504AB,
LEECE-NEVILLE MODEL 2184AC,
NSN 2920-00-782-1955
LEECE-NEVILLE MODEL 5300GP,
NSN 2920-00-818-8635
TM 9-2920-225-34P dated 1974
(INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS) GENERATOR, ENGINE ACCESSORY
(ALTERNATING CURRENT)
(FSN 2920-909-2483)
LEECE-NEVILLE MODELS 3002AC AND 3002AD
(FSN 2920-909-2483)
5504AA AND 5504AB (FSN 2920-475-1446)
2184AC (FSN 2920-782-1955)
5300GP (FSN 2920-818-8635)
Guyfang
27,263
TM 9-2815-221-34&P dated 1985
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST), Engine, Diesel, Industerial Type, Model (DJEME) NSN 2815-01- 175-7342, Model (DJBMA) (NSN 2815-00-615-8740
TM 9-2815-250-24&P dated 1988
UNIT, DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR ENGINE ASSEMBLY, DIESEL HATZ 2 G 40 (NSN 2815-01-446-3500) EIC: AKA
Guyfang
27,263
TM 9-4910-571-12&P dated 1984
TECHNICAL MANUAL, OPERATOR'S AND ORGANIZATIONAL MAINTENANCE MANUAL, INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST , SIMPLIFIED TEST EQUIPMENT FOR INTERNAL COMBUSTION ENGINES
( NSN 4910-00-124-2554
Guyfang
27,263
TM 9-2540-205-24&P dated 1992
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR Heaters, Vehicular Compartment, for:
STEWART-WARNER
1056OC24 (NSN 2540-01-063-0691)
10560M (NSN 2540-01-071-0651)
10560M24B1 (NSN 2540-01-169-5159)
10560G (NSN 25404)1-262-6013)
HUPP
MF510B (NSN 2540-01-071-0652)
MF510C, MF60B-24V (NSN 2540-01-162-3834)
MF60A-24V (NSN 2540-00-930-8838
ESPAR
V7S (NSN 2540-01-114-7688
Guyfang
27,263
TM 9-5130-338-12&P dated 1997
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR WRENCH, IMPACT, HYDRAULIC, MODEL IW-12-140T, (PN 12322630) ,(NSN:5130-00-790-2284)
TM 9-5130-338-13&P dated 1961 wc#1
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR WRENCH, IMPACT, HYDRAULIC, (BOWEN-McLAUGHIN-YORK, MODEL BML15436)
NSN: 5130-790-2284
