Allison 3000 Transmission Pan Jacking Bolts
Delirium
Raleigh, North Carolina
Hey y'all, working on getting at the guts of the MD3070PT in my M1078A1 for a thorough run-through and casual glitter hunting. The TMs and TS2973EN have been great so far, but there's one thing hanging me up as of this past weekend: The jacking bolt threads on the transmission pan. They are mentioned in 34-2 on page 7-71 and nowhere else, not even in Allison's documentation. Anyone know what size bolt is needed for those? I've gone through my bucket-o-bolts and can't seem to find anything that works, and I'd like to avoid getting physical with the pan and marring the separator plate or worse.
GeneralDisorder
6,192
Portland, OR
Typically in such cases they are designed to use the control valve body assembly mounting bolts (once removed) as the jacking bolts. I don't know that for a fact but that is convention in the industry so I HIGHLY suspect that is the case here.
That's not a pan. It's a control valve body assembly that happens to double as a sump. Be prepared as it is VERY heavy.
Delirium
To close this out, the jacking bolt hole in the rear of the assembly was the one I wasn't looking at but should have been. There are holes on either side of the assembly that 'look' like they are jacking bolt holes, but they are in fact blanks where the guide pins are at, thus explaining my confusion. I found a real horror show in the valve body assembly itself, that'll be a whole separate thread.
