Military Vehicle, Recovery Vehicle, Full-Tracked: LIGHT ARMORED, M578, (2350-00-439-6242)
Guyfang
26,877
Burgkunstadt, Germany
Recovery Vehicle, Full-Tracked: Light Armored, M578, (2350-00-439-6242)
Any information printed in Red, is not allowed to be posted in the forum, due to the TM Classification, or simply not to be found.
Guyfang
26,877
LO 9-2350-238-12 dated 1990 wc#1
LUBRICATION ORDER, RECOVERY VEHICLE, FULL-TRACKED: LIGHT, ARMORED, M578, (2350-00-439-6242)
TM 9-2350-238-10 dated 1990 wc#4
OPERATORS MANUAL, RECOVERY VEHICLE, FULL-TRACKED: LIGHT, ARMORED, M578 (2350-00-439-6242)
TM 9-2350-238-20-1 dated 1994
TECHNICAL MANUAL, UNIT MAINTENANCE MANUAL, HULL AND RELATED COMPONENTS, RECOVERY VEHICLE, FULL-TRACKED: LIGHT, ARMORED, M578, (2350-00-439-6242)
TM 9-2350-238-20-2 dated 1992 wc#2
T E C H N I C A L M A N U A L, U N I T M A I N T E N A N C E M A N U A L CRANE (CAB) COMPONENTS
RECOVERY VEHICLE, FULL-TRACKED: LIGHT, A R M O R E D , M 5 7 8, ( 2 3 5 0 - 0 0 - 4 3 9 - 6 2 4 2 )
TM 9-2350-238-24P-1 1994
ORGANIZATIONAL MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS FOR RECOVERY VEHICLE, FULL-TRACKED: LIGHT, ARMORED, M578, (2350-00-439-6242)
TM 9-2350-238-24P-2 1992 wc#1
TM 9-2350-238-34-1 1994
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL, HULL AND RELATED COMPONENTS, RECOVERY VEHICLE, FULL-TRACKED: LIGHT, ARMORED, M578, 2350-00-439-6242)
TM 9-2350-238-34-2 1992 wc#2
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL, CRANE (CAB) COMPONENTS, RECOVERY VEHICLE, FULL-TRACKED: LIGHT, ARMORED, M578 (2350-00-439-6242)
TM 9-2350-238-PCL 1990
COMBAT VEHICLE, PRE-COMBAT CHECKLIST FOR: RECOVERY VEHICLE, FULL TRACKED LIGHT ARMORED, M578, ( 2 3 5 0 - 0 0 - 4 3 9 - 6 2 4 2 )
Guyfang
26,877
TM 9-2815-202-24P 2003
TECHNICAL MANUAL, REPAIR PARTS AND SPECIAL TOOLS LIST FOR ENGINES, DIESEL WITH CONTAINERS
MODEL 7083–7391
NSN 2815–01–335–4579 (EIC N/A)
MODEL 7083–7395
NSN 2815–01–043–7092 AND
NSN 2815–01–260–0211 (EIC N/A)
MODEL 7083–7396
NSN 2815–01–040–3120 AND
NSN 2815–01–260–0212 (EIC N/A)
TM 9-2815-202-34 1990 wc#1
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE,
ENGINE, DIESEL W/CONTAINER, MODEL 7083-7395 (2815-01-043-7092), (2815-01-260-0211)
ENGINE, DIESEL W/CONTAINER, MODEL 7083-7396 (2815-01-040-3120), (2815-01-260-0212)
ENGINE, DIESEL W/CONTAINER, MODEL 7083-7398 (2815-00-936-7659)
ENGINE, DIESEL W/CONTAINER, MODEL 7083-7399 (2815-00-134-4845)
TM 9-2815-202-34&P 1980
DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE, INCLUDING REPAIR PARTS AND SPECIAL TOOLS LISTS FOR ENGINE , DIESEL: TURBOCHARGED, FUEL INJECTED , LIQUID COOLED, "V" TYPE, 8 CYLINDER,
W/CONTAINER ASSEMBLY
DETROIT DIESEL- GMC SERIES 8V71T
MODEL 7083-7398, (NSN 2815-00-762-4500 and 2815-00-936-7659) ,
MODEL 7083-7395, (NSN 2815-01-043-7091 and 2815-01-7092),
MODEL 7083-7399 ( NSN 2815-00-134-4845) AND
MODEL 7083-7396 ( NSN 2815-01-040-3120)
Guyfang
26,877
TM 9-2520-234-34P dated 1991
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST (INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS) FOR:
POWER TRAIN ASSEMBLY (8351100) (ALLISON MODEL XTG411-2A)
COMPOSED OF:
TRANSFER ASSEMBLY, TRANSMISSION INPUT (2520-00-894-9535),
TRANSMISSION ASSEMBLY (2520-00-894-9533],
DRIVE ASSEMBLY, TRANSMISSION OUTPUT, VEHICLE LEFT [2520-00-894-9534),
DRIVE ASSEMBLY, TRANSMISSION OUTPUT, VEHICLE RIGHT [2520-00-894-9532]
WITH COUPLING (2520-00-736-3581) AND PARTS;
POWER TRAIN ASSEMBLY (8355953) [ALLISON MODEL XTG411-2A]
COMPOSED OF:
TRANSFER ASSEMBLY, TRANSMISSION INPUT [2520-00-894-9535),
TRANSMISSION ASSEMBLY (2520-00-894-9533)
POWER TRAIN ASSEMBLY (8351763) (ALLISON MODEL XTG411-2A)
COMPOSED OF:
WITH YOKE ADAPTER (2520-00-818-051O) AND PARTS;
POWER TRAIN ASSEMBLY (11650290) (ALLISON MODEL XTG411-4)
COMPOSED OF:
TRANSFER ASSEMBLY, TRANSMISSION INPUT (2520-01-282-1228,
TRANSMISSION ASSEMBLY (2520-01-282-1224),
DRIVE ASSEMBLY, TRANSMISSION OUTPUT, VEHICLE LEFT (2520-00-894-9534),
DRIVE ASSEMBLY, TRANSMISSION OUTPUT, VEHICLE RIGHT (2520-00-894-9532)
POWER TRAIN ASSEMBLY (11650289) (ALLISON MODEL XTG411-4)
COMPOSED OF:
WITH COUPLING (2520-00-736-3581 AND PARTS;
POWER TRAIN ASSEMBLY (11650300) (ALLISON MODEL XTG411-4)
COMPOSED OF:
WITH YOKE ADAPTER (2520-00-818-0510) AND PARTS
TM 9-2520-234-35 dated 1962 wc#2
FIELD AND DEPOT MAINTENANCE MANUAL, FOR:
(8351100)
(ALLISON MODEL XTG-411-2A)
COMPOSED OF:
TRANSFER ASSEMBLY, TRANSMISSION INPUT,
(2520-894-9535)
TRANSMISSION ASSEMBLY,
(2520-894-9533)
VEHICLE LEFT
(2520-894-9534)
VEHICLE RIGHT
Guyfang
26,877
TM 9-2540-205-24&P dated 1992
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR Heaters, Vehicular Compartment, for:
STEWART-WARNER
1056OC24 (NSN 2540-01-063-0691)
10560M (NSN 2540-01-071-0651)
10560M24B1 (NSN 2540-01-169-5159)
10560G (NSN 25404)1-262-6013)
HUPP
MF510B (NSN 2540-01-071-0652)
MF510C, MF60B-24V (NSN 2540-01-162-3834)
MF60A-24V (NSN 2540-00-930-8838
ESPAR
V7S (NSN 2540-01-114-7688
Guyfang
26,877
TM 9-2350-274-BD dated 1984 wc#3
TECHNICAL MANUAL, OPERATORS, ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE, Battle Damage Assessment and repair, for M109/M110/M578 VEHICLES:
HOWITZER, MEDIUM, SELF-PROPELLED, FULL-TRACKED
M109A2 Howitzer
NSN 2350-01-031-4586 (EIC: 3EZ)
M109A3 Howitzer
NSN 2350-01-031-8851 (EIC: 3E2)
M109A4 Howitzer
NSN 2350-01-277-5770 (EIC: 3E8)
M109A5 Howitzer
NSN 2350-01-281-1719 (EIC: 3E7)
M110A2 Howitzer
NSN 2350-01-041-4590 (EIC: 2E3)
M578 Recovery Vehicle
NSN 2350-00-439-6242 (EIC: 3LA)
Guyfang
26,877
TM 9-5130-338-12&P dated 1997
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR WRENCH, IMPACT, HYDRAULIC, MODEL IW-12-140T, (PN 12322630) ,(NSN:5130-00-790-2284)
TM 9-5130-338-13&P dated 1961 wc#1
TECHNICAL MANUAL, OPERATOR'S AND UNIT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR WRENCH, IMPACT, HYDRAULIC, (BOWEN-McLAUGHIN-YORK, MODEL BML15436)
NSN: 5130-790-2284
