Power Steering
G744
4,118
Hidden Valley, Az
The best one I ever saw some 40 years ago was a hydraulic torque amplifier unit mounted under the dash.
It was on beefy homemade brackets, and the stock steering shaft was customized to fit. They used the stock steering box.
I didn't get to see the pump/reservoir, but that would be academic anyway.
The thing looked more-or-less cylindrical, about 6" diameter, 6 or 7" long, shafts out each end. Pretty neat job.
In later years, I saw the same tech used in bigger dunebuggies in the Yuma dunes.
PoW
GT4U
23
IL
Has anyone ever done electric power steering? I've seen some electric power steering conversions done on midsize tractors for under $200 dollars using Prius power steering parts, seems like it might work for this application.
