Mep 831A load issues
grywitt
184
Nm
I see in the pics and videos that somewhere in it's life someone cut the safety wires off the two mechanical governor adjustments. Not good... Those are adjusted at the factory and normally would not ever be messed with. Someone messed with those adjustments.
In the short video the governor arm does not stick to the magnet causing problems with not shutting down properly. My hunch is that someone messed with the strength of the magnet and now it's not strong enough.
The magnet strength can be adjusted. If you loosen the nut securing it to the bracket you can rotate the magnet inside the round collar to move it closer to the collar opening to make it stronger.
The magnet strength has to be set strong enough for the arm to stick to it at shutdown but no so strong that the Governor Controller can't pop it off the magnet at startup.
Is the rod adjusted so the gap is set to 5/16" running at no load?
I do have it set to 5/16 at no load. That little piece of lead just fell off in the last couple days. It was only hanging on by one side and I've been moving the gen around to get the exhaust off and stuff. The magnet not holding just happened basically over night. I can promise I didn't need with the magnet and I don't think I bumped and bent it either but it stopped holding. I'm kind of baffled on that part.
I guess I can move the magnet out and keep really close track of how much I move it.
grywitt
184
Nm
grywitt
184
Nm
Sorry I really need to get better at proof reading before i send. Sometimes I go back and i have a hard time figuring out what I was saying. " I didn't mess with the magnet "
grywitt
184
Nm
Well this morning was pretty informative. Apparently the times I've held 3kw were all first run of the day. Today it held 3kw for a bit before starting to choke. Also thank you kloppk for the magnet fix. The tms say don't touch that so I haven't but I moved it just enough to grab the arm and now my not shutting down problem is gone. Yay!!
In reading the TMs the one thing comon to my problem seems to be injector. I ordered one with the same part number as the TM calls out but it's too long. 714350 53100 yes? I'll keep trying. This gen will run great eventually.
BTW. I was out there checking voltages ect and with no load 5/16 gap I'm running 172 and with load 2.75kw a high as she will hold I'm at 186. Is this acceptable with how you've built the boards? I did run with the actuator held open and adjusted the throttle to 219 like the instructions say
kloppk
4,171
Pepperell, Massachusetts
Close enough.
My board measures the AC Frequency to measure the engine RPM. So, at no load the RPM should be about 3,050 RPM (254 Hz PMA Frequency).
It adjusts the throttle to achieve the required RPM based on the Load signal from the inverter so that the engine RPM is correct for the load.
grywitt
184
Nm
Close enough.
Copy that. Thank you. I figured but right now I'm trying to make sure I check every possibility. So the not shutting down came back again. I'm pretty sure i got it now. The actuator arm is/ was slipping on its rod. It had been squeezed down to much and I'm still not sure it won't again but I seem to have it holding. Thanks again for your time.
grywitt
184
Nm
Ha ha. I bet none of you guys have ever had a machine that just wouldn't give you a break. The not shutting down thing came back. The way I figured out it's slipping on the shaft is after shutting it down and holding it over against the magnet there is a little gap even when you are pushing it over. Readjust and it's good for a couple times. But just for good measure the fuel pump quit working. It's definitely the pump. I have 24 volts and if I put the plug on the other pump it runs. It would be funny if the power issue was a failing fuel pump.
grywitt
184
Nm
Update: new fuel pump, New injector and no governor control. Well the mechanical governor is working. I decided to just run it with the mechanical governor since I'm having trouble with the arm slipping on the rod. Technically no change. I did get it to hold 3kw for a minute or so but it started smoking and was ready to die when I dropped it back down to 2kw.
I've ran it now for several hours at load try and clean out and carbon. ( well the load it would hold anyway). I'm running out of ideas. I guess I could just call it a 2kw gen. Oh BTW it was spitting a bit when I had it at 3kw. I'm not sure how else to describe it. Little interruptions in smooth. I was pulling out my phone to try to video but it was about to die so I didn't have time.
I don't have the tools or knowledge to do a compression test. Maybe find a diesel mechanic to look at it. Any one want an 831A?
2Pbfeet
1,465
Mt. Hamilton, CA
When you write "spitting", do you mean it was stumbling and dropping rpms?
Can you run it at 2.5kW for a bit? I would keep your altitude de-rate in mind as the full 3kW at your altitude may be pushing it, though you might be able to work up to it by more hours at 2.5-2.7kW.
All the best, 2PbFeet
grywitt
184
Nm
Almost like backfiring I guess I would call it. I'm sorry it's pretty hard to describe. It seemed to be holding it's rpm's okay. You can tell when it's about to choke. The smoke gets thicker and thicker and it coughs some and if I don't reduce load it will then start reducing rpms until it drops the contact. You are right. I did want to get my hands on one of those 2kw gens and this way I can have a 2kw TQG. Lol. Heck at 2kw it runs nice!
I'll keep exercising it and see what happens. She's up to a whopping 35 hours already now.
grywitt
184
Nm
Stumbling and dropping rpms comes later after the spitting. Ha ha
Sounds funny. Maybe later I'll see if i can catch it on video
grywitt
184
Nm
This is after running about an hour at 2500 watts. really seems to be pushing out a lot of smoke and carbon. I reassembled the gen today and routed the fuel lines in what i hope is a way to keep the 2nd tee in the highest position hopefully keeping any air flowing back to tank.
Even with derating I would think it might not smoke so much at 2.5kw. The manual and the TM talk about carbon in the combustion chamber if output drops and I'm pretty positive I do have that. Heck the injector is always covered in carbon when I take it out. I'm not sure how it's supposed to look. If nothing else I'm learning a lot about this engine. I'll give it another 10 hours then I'm going to pull the head and do the valve stem and spring checks it talks about to. If the hours are right it's probably not the problem.
One good thing is the engine still runs after taking things apart a few times. Since it's still running the same I think I haven't found the problem yet and I'm being a parts changer. Ugh.
Anyway it's almost new. Ha ha.
grywitt
184
Nm
I see why you say my gen might actually only have 35 hours. The 831s on GP the exhaust wrap looks way different than mine even the ones with only 100 hours. Maybe i really do have a 35 hour machine. I hopefully get it tip top eventually. I had to move on to other projects for a while. I've about got all my other gens running and putting out power correctly now. Anyway I haven't been exposed to these gens so seeing what you were taking about caught my attention.
2Pbfeet
1,465
Mt. Hamilton, CA
Yes, it was the clean exhaust wrap, the spotlessly clean air cooling fins, clean fans, to name a couple, and that was despite the sand and gravel inside. It was also that none of the engine parts seemed to have been exposed to much heat either, as your gaskets came off very cleanly.
That cleanliness was in contrast to the carbon in the muffler, and the soot laden oil that looked as if the oil had run for a long time.
To me all of that argued for a lower hour engine with something really off in combustion, like bent push rods and an air leak.
Given the challenges that you have gotten through, I'm inclined to wonder if this engine came from the factory with something not right, and various individuals fiddled with it trying to figure out the issues, loading it up with carbon as they fiddled. I have my fingers crossed that you have "the issues" sorted out now and the original cause was something small like valve clearances that were too tight, and those triggered the bent push rods, that messed up the combustion, perhaps aided and abetted by an air leak in the fuel line and/or poor priming.
At the moment, since it runs fine at 2.5kW, if it were mine, I'd run it there for awhile before bumping up to 2.7kW. Unlike some of the bigger TQG units, it is my perception that this one does not have a lot of extra power in reserve. The L70engine is rated only for a max of 4.8kW, and a continuous rating of 4kW before all of the energy lost to fans, the inverter efficiency losses, etc. To me, that's not a great deal of reserve over the 3kW electrical output.
https://yanmarengines.com/wp-content/uploads/2020/07/L-Series-Brochure-2016-No-Cover.pdf
grywitt
184
Nm
Well i found my cheap little camera bore scope thing and tried to get good footage down in the cylinder. From what I can tell it looks brand new in there. Heck I'm wondering where all the soot is that i see on the injector. I wish I could turn it over and look up with it but it's not that nice. I have a little mirror that can screw onto it but it didn't help much.
The spacer and gasket came out with the injector this time so I had more room to enter. I ran the gen yesterday for about 7 hours loaded to 2250 or 2500 depending on how much it was smoking
It still seems to smoke quite a bit even at 2500 watts and even 2250. At 2k it seems pretty clean. Anyway I found that camera and decided to look inside. It fired up and ran afterwards bit I didn't load it. I'm just glad it runs after I did into it. Ha ha.
grywitt
184
Nm
This is about 10 hours of running at load worth of soot. I had it clean before that. Normal? I watched a u tube video of a guy saying if your at 3 to 4000 feet maybe remove a shim if it's smoking. I only have one but I tried it. It runs exactly the same without its shim. I'll keep researching but just am posting in case something i find means something to someone.
2Pbfeet
1,465
Mt. Hamilton, CA
No, I would describe that as not normal. However, I am not sure that any of us know how much carbon was already inside your muffler which does I think make it a bit difficult to interpret.
How does the engine run without the muffler? (E.g. Smoke onset at what load?) After ten hours of loading to less than smokey conditions, I would have expected some more improvement. Is this the original injector?
grywitt
184
Nm
I did buy and install a new injector just to see if it made a difference. I have the original still. I haven't tried running it without the muffler to know that answer. Even at 2250 watts there is still some smoke coming out. It's hard to get on video but depending on the angle still some. 2kw seems to be the highest i can go without smoke. Does that mean I shouldn't run above 2 for 10 hours first? Now that I changed the injector the spacer and gasket come out with it now. I think it might be time to open it up. Unless you think I should put more hours on it loaded? I feel like something still just isn't quite right. My exhaust wrap doesn't look as nice now so it's looking older now. Lol.
grywitt
184
Nm
Also both injectors looked the same when they came out. Pretty coated in carbon. It's that pretty normal?
