Reworked LMTV
Expedition Campers Limited, LLC
- 1,558
- 1,213
- 113
- TN
Just rec'd, my cab hydraulic ram upgrade kit. There is a diagram, but no real instructions. Anyone else complete this upgrade?
What position did you have your cab in when you did the swap? Did you wedge a bar in there for safety?Yes I did this a few months ago, View attachment 952561very vague instructions.
The TM has technicians support the cab with a "suitable lifting device" but I did the whole job using the Cab Support Tool. Swapping the ram itself is super easy. Just have air in the tanks and with the cab supported in the partially raised position with the support bar you can disconnect the bottom of the ram and pump the ram into the fully lowered position so you retain as much of the system fluid as possible. You will lose some.What position did you have your cab in when you did the swap? Did you wedge a bar in there for safety?
IMO the cab support tool should have been part of the BII. That's literally the hood prop!Along with the new heavy duty cylinder I purchased the military cab prop tool, basically lift the cab put the support tool in between the latch and the cab then lower the cab onto it. Then you can safely remove the cylinder. The biggest problem is that it limits how much room you have to work on it.
Yep. It us not horribly difficult to replicate but you have to be sure of how you are doing it as there is not much room for error. A proven method would be safer for most all concerned…IMO the cab support tool should have been part of the BII. That's literally the hood prop!
I have the parts kit for this but I've not done it. My cab is bent upwards, in this same photo of mine so I have to bend it back firstYes I did this a few months ago, View attachment 952561very vague instructions.
