Looking for MEP-003A and M116A2 stuff - bows, vinyl cover, suppression kit, etc.
1,161
Hey everybody
So, I've always said I didn't want a generator, as I felt my power was so reliable that I'd do more maintenance to a genset than I'd actually use it. But my power has been going out more frequently, and for longer periods in the last couple of years. And the giant storm a few months ago that wiped out Augusta and Asheville had originally been forecast to go right through Athens, Ga., where I live.
A friend of mine has a great setup with his shop and house running off an MEP-003A and I've decided to copy that. And that same friend scored me a great deal on a 003A with reasonable hours and an M116A2 trailer. The genset will need some maintenance to bring it back to my standards, and so will the trailer. No biggie.
Judging from the pictures below, you can tell some of the stuff I'll need.
  • A green vinyl M116A2 cover. This is the cover that goes all the way down to the trailer and has allowances for the wheelwells. Like this:
  • A full set of bows.
  • Extra jerry can mounts and the toolbox seen above. I will probably not restore the trailer to 100% correctness, as I'm probably going to add a larger fuel tank, civilian lights so I can pull it with my 4500 as well as Deuce, etc.
  • An NOS 10-pin trailer wiring connector. This one, the rubber end is rotting.
  • NOS data plates for the genset and the trailer. I already found an NOS id tag for the trailer, the one that has the VIN and such. I'm going to repaint the genset and the trailer and I'd love to replace all the data plates.
  • I think Eastern has NOS brake assemblies for the passenger side, does anyone has NOS drivers side units?
  • If it exists, I'd love to have an NOS gauge panel:
  • I'd love to have a noise suppression kit (ASK – Acoustic Suppression Kit) for this thing. It's going to be out under an awning by my shop and it'll only be 220' from my closest neighbor. If it runs for a day, I can see a neighbor getting whiny. I think the suppression kits for these are uncommon? I don't remember seeing many. I know I could make something, but I have zero extra time in my life. I'd rather just buy something and paint/reinsulate it.
    Like this: https://greenmountaingenerators.com/product/mep003a-sound-kit-ask-acoustic-suppression-kit/
When I get further into the restoration of the units this winter, I'll probably need more but this is what I know of for now.
Thanks
C
Guyfang
26,962
Burgkunstadt, Germany
I know I would be talking to @Ray70 about his spin on fuel filter upgrade if that set was mine.
The ASK kit has a serious trade off to it. Yes it makes that gen set much easier to live with. But it make maintenance more of a pita. It also can attract mice like a magnet.
Looking forward to you working on the Gen set. If taken care of, that set is bomb proof.
1,161
Ok, so far I have managed to score:
A new dataplate for the trailer
New trailer wiring connector
A spare wheel
My gooseneck trailer uses the same tires and I'm about to replace them, I'll keep the best 3 and mount them on these wheels
Tinstar's NOS gauge panel
Diaper pin clips for the d-rings
NOS gas cap for the generator
New oil pressure shutdown switch
New voltmeter
I'm still looking for the correct bows and vinyl cover.
I'd love to find any NOS dataplates for the generator itself
Thanks!
1,161
I am still looking for all of the stuff above:
I need M116A2 data plates
ALL of the MEP-003A data plates (only interested in NOS)
M116A2 bows and cover
I'd buy an Acoustical Suppression Kit in any condition (doesn't have to be NOS)
So, I'm slowly making headway on this thing. I replaced the hacked up oil drain hose with the correct unit.
This was all hacked up and didn't have the fitting on the left to attach to the deadhead fitting
I received Tinstar's NOS panel (thanks again!) and installed an NOS voltmeter in it:
I also have civilian LED taillights, a civvy 7 pin connector and some other stuff.
As soon as the filters and oil show up, I'm going to go through all of the fuel pumps, do all the filters, clean out the fuel tank, etc.
Anyone have any of those parts on my list?
1,161
i have bows in OKlahoma
Excellent!
I know they'd have to go truck freight, so let me see if I can find a friend going to or coming from OK soon.
Thanks
1,161
bump
I'm still looking for:
NOS M116A2 data plates (I have the one you stamp the trailer VIN in, I need the others (weight and center of gravity plate, the genset data plate, etc.)
Also, there is an SS user in Oklahoma who has the bows, but we need to find a way to get them to me. Transport thread here: https://steelsoldiers.com/threads/t...-a-couple-hundred-miles-of-atlanta-ga.223954/
Thanks
Ray70
7,070
West greenwich/RI
I've got an 003 ASK up here in RI. It would need some new insulation and some paint work, but I had done a full restoration on its brother ( I bought a trailer with a pair of 6 hour 003AASK's on it) a few years back and it came out pristine! I've even got the full set of stencils around here somewhere I bet.
On yea... I've got spin on fuel and oil adapter bases as well :cool:
1,161
Hey Ray,
For now, I have purchased a full set of original style oil and fuel filters. I would like to upgrade to spin-on's at some point, but I'm spending a lot of money right now on a couple of big long term projects, so I'm going to have to hold off on the spin-on conversion.
If there is a way to get the ASK stuff down here to Ga., I'd be interested. I don't mind restoring the ASK kit, I'm already going to be repainting the 003A and the 116 trailer. And the insulation isn't a big deal.
Can the panels be unbolted and strapped to a pallet?
glcaines
2,794
Hiawassee, Georgia
Clint, I saw from your first post that you were likely going to add a larger fuel tank. Did your genset com with the auxiliary fuel line? That is the way to go since the aux fuel pump on the MEP003A will pull fuel through that line and keep the day tank topped off. I have an MEP003A that I've had for many years and it gets a routine workout due to power outages where I live. That genset is fantastic. No problems and air cooled, so no coolant issues. You will love it. It is big enough to handle my entire house, including geothermal heat pump, etc so I didn't have to pick which circuits to back up. I installed a 400-amp Square-D manual transfer switch. I also used the 3 Phase output for my workshop for years until I installed a rotary phase converter. If you are ever up in the Hiawassee area you are welcome to stop by and check out my installation.
Ray70
7,070
West greenwich/RI
I'm sure it can be unbolted the resto of the way and palletized and shipped, but I unbolting was a little bit of a problem on the other one.
What happened was that many of the nut inserts holding the panels into the shape of a box spun when trying to remove the bolts, so I ended up cutting the heads off the bolts, replacing the nut inserts with 1/4-20 Rivnuts and reassembling with 1" 1/4-20 shoulder bolts where needed.
There is a possibility I will be going to Florida with the family in late Oct. so perhaps I could take it with me and meet you somewhere as well?
