MILITARY VEHICLE, CARRIER, PERSONNEL, FULL-TRACKED, ARMORED, M 113A2, 2350-01-068-4077 & LIKE VEHICLES
Guyfang
27,246
Burgkunstadt, Germany
CARRIER, PERSONNEL, FULL TRACKED, ARMORED, M113A2, NSN 2350-01-068-4077
CARRIER, COMMAND POST, LIGHT TRACKED, M577A2, NSN 2350-01-068-4089
CARRIER, MORTAR, 120-MM, M121; SELF-PROPELLED, M1064, NSN 2350-01-338-3116
CARRIER, STANDARDIZED INTEGRATED COMMAND POST SYSTEM, M1068, NSN 2350-01-354-5657
CARRIER, SMOKE GENERATOR, FULL TRACKED, M1059, NSN 2350-01-203-0188
COMBAT VEHICLE, ANTI-TANK, IMPROVED TOW VEHICLE, M901A1 NSN 2350-01-103-5641
A Big Thanks to Member @drspooks for several of these TM's!
Any information printed in Red, is not allowed to be posted in the forum, due to the TM Classification, or simply can not to be found.
Guyfang
27,246
LO 9-2350-261-12 dated 1990 wc#4, LUBRICATION ORDER FOR:
CARRIER, PERSONNEL, FULL TRACKED, ARMORED, M113A2, 2350-01-068-4077
CARRIER, COMMAND POST, LIGHT TRACKED, M577A2, 2350-01-068-4089
CARRIER, MORTAR, 107-MM, M30; SELF-PROPELLED, M106A2, 2350-01-069-6931
CARRIER, MORTAR, 81-MM, M29A1; SELF-PROPELLED, M125A2, 2350-01-068-4087
CARRIER, SMOKE GENERATOR, FULL TRACKED, M1059, 2350-01-203-0188
CARRIER, MORTAR, 120-MM, SELF-PROPELLED, M1064, 2350-01-3383116
CARRIER, STANDARDIZED INTEGRATED COMMAND POST SYSTEM, M1068, 2350-01-354-5657
TM 9-2350-261-10 dated 2005
TM 9-2350-261-20-1 dated 2005
TM 9-2350-261-20-2 dated 2005
TM 9-2350-261-20-3 dated 2005
TECHNICAL MANUAL, OPERATOR’S MANUAL FOR:
CARRIER, PERSONNEL, FULL TRACKED, ARMORED, M113A2 NSN 2350-01-068-4077
CARRIER, COMMAND POST, LIGHT TRACKED, M577A2 NSN 2350-01-068-4089
CARRIER, MORTAR, 120-MM, M121; SELF-PROPELLED, M1064 NSN 2350-01-338-3116
CARRIER, STANDARDIZED INTEGRATED COMMAND POST SYSTEM, M1068 NSN 2350-01-354-5657
CARRIER, SMOKE GENERATOR, FULL TRACKED, M1059 NSN 2350-01-203-0188
TM 9-2350-261-24P dated 2005
TECHNICAL MANUAL, UNIT MAINTENANCE, DIRECT AND GENERAL SUPPORT MAINTENANCE, REPAIR PARTS AND SPECIAL TOOLS LIST (INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST) FOR:
CARRIER, PERSONNEL, FULL TRACKED, ARMORED, M113A2 (NSN 2350-01-068-4077)
CARRIER, COMMAND POST, LIGHT TRACKED, M577A2 (NSN 2350-01-068-4089)
CARRIER, MORTAR, 120-MM, M121; SELF PROPELLED, M1064 (NSN 2350-01-338-3116)
CARRIER, STANDARDIZED INTEGRATED COMMAND POST SYSTEM, M1068 (NSN 2350-01-354-5657)
CARRIER, SMOKE GENERATOR, FULL TRACKED, M1059 (NSN 2350-01-203-0188
COMBAT VEHICLE, ANTI-TANK, IMPROVED TOW, VEHICLE, M901A1 (NSN 2350-01-103-5641)
TM 9-2350-261-34 dated 2005
TM 9-2350-261-PCL dated 1990
COMBAT VEHICLE
PRE-COMBAT CHECKLIST FOR:
CARRIER, PERSONNEL, FULL TRACKED, ARMORED, M113A2, (2350-01-068-4077)
CARRIER, COMMAND POST, LIGHT: TRACKED, M577A2, (2350-01 -068-4089)
CARRIER, MORTAR: 107 MM, SELF-PROPELLED, M106A2, (2350-01-069-6931)
CARRIER, MORTAR: 81 MM, SELF-PROPELLED, M125A2, (2359-01-068-4087)
CARRIER, SMOKE GENERATOR, FULL TRACKED, M1059, (2350-01-203-0188
TM 9-2350-261-PMCS dated 1987
CREW DAILY PMCS FOR OPERATOR’S MANUAL:
CARRIER, PERSONNEL, FULL TRACKED, ARMORED M113A2, 2350-01486-4077
CARRIER, COMMAND POST, LIGHT, TRACKED M577A2, 2350-01-0684089
CARRIER, MORTAR, 107-MM, SELF PROPELLED M106A2, 2350-01-069-6931
CARRIER, MORTAR, 81-MM, SELF PROPELLED M125A2, 2350-01-068-4087
CARRIER, SMOKE GENERATOR, FULL TRACKED M1059, 2350-01-203-0188
TM 9-2350-261-10-HR dated 1991
HAND RECEIPT, COVERING CONTENTS OF COMPONENTS OF END ITEM (COEI), BASIC ISSUE ITEMS (Bll)
AND ADDITIONAL AUTHORIZATION LIST (ALL) FOR:
CARRIER, COMMAND POST, LIGHT TRACKED, M577A2, (2350-01-068-4089)
CARRIER, MORTAR, 107-MM, M30; SELF-PROPELLED, M106A2, (2350-01-069-6931)
CARRIER, MORTAR, 81-MM, M29A1 ; SELF-PROPELLED, M125A2, (2350-01-068-4087)
Guyfang
27,246
TM 9-2815-205-24 dated 2013
TECHNICAL MANUAL, FIELD AND SUSTAINMENT MAINTENANCE, FOR, 6V53/6V53T ENGINES, DIESEL WITH CONTAINERS:
MODEL 5063-5299
NSN 2815-00-124-5390
NSN 2815-01-295-7458
MODEL 5063-5392
NSN 2815-01-246-0903
MODEL 5063-5393
NSN 2815-01-248-7644
MODEL 5063-539L
NSN 2815-01-412-2715
TM 9-2815-205-24P dated 2013
TECHNICAL MANUAL, FIELD AND SUSTAINMENT MAINTENANCE, REPAIR PARTS AND SPECIAL TOOLS LIST (RPSTL) FOR 6V53/6V53T ENGINES, DIESEL WITH CONTAINERS:
MODEL 5063-5299
MODEL 5063-5392
MODEL 5063-5393
MODEL 5063-539L
Guyfang
27,246
TM 9-2520-238-34 dated 2001
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL FOR:
RIGHT ANGLE DRIVE, COOLING FAN
M113A1 FOV, M113A2 FOV — 2990-00-712-1280
M113A3 FOV — 3010-01-318-5670
GEARCASE, TRANSFER
M548, M548A1—2520-01-047-8613
SERVICE GEARCASE — 2520-01-087-0156
M113A1 FOV — 2520-00-572-8605
M113A2 FOV WITH 100 AMP GENERATOR— 2520-01-061-5570
M113A1 FOV, M113A2 FOV WITH 200 AMP GENERATOR—2520-01-362-8589
DRIVE ASSEMBLY, FINAL
M113A2 FOV, M113A3 FOV — 2520-01-061-5766
M548, M548A1— 2520-01-067-8933
DIFFERENTIAL, STEERING CONTROL
M113A1 FOV, M113A2 FOV, M548, M548A1— 2520-00-714-6135
BRAKE, SINGLE DISK
M113 FOV, M548, M548A1—2530-00-088-9866
CYLINDER ASSEMBLY, HYDRAULIC BRAKE
M113 FOV, M548, M548A1—2530-00-679-9169
TM 9-2520-238-34P dated 2001
DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE, REPAIR PARTS AND SPECIAL TOOLS LIST
(INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPEICAL TOOLS LIST) FOR:
GEARCASE, TRANSFER
BRAKE, SINGLE DISK
Guyfang
27,246
TM 9-2920-257-30&P dated 1987 wc#1
TECHNICAL MANUAL, DIRECT SUPPORT MAINTENANCE MANUAL, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS) FOR:
GENERATOR, ALTERNATING CURRENT, 200 AMPERES (Leece-Neville)
NSN 2920-01-147-1575
NSN 2920-01-238-9710
AND
GENERATOR, ALTERNATING CURRENT, 200 AMPERES (Niehoff)
NSN 2920-01-292-2993
NSN 2920-01-298-8072
Guyfang
27,246
The 4.2 Generator Set, Less Engine
TM5-6115-596-14 dated 1980 wc#4
TM5-6115-596-14 Extracted Wire Diagrams
TM5-6115-596-24P dated 1980 wc#6
TECHNICAL MANUAL, OPERATOR’S, ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT
GENERATOR SET: GASOLINE ENGINE DRIVEN,
4.2 KW, 150 AMP, 28V, DC
MODEL DC 4.2- ORD/28 (6115-00-857-1397)
Engine, Gasoline Driven
TM 9-2805-269-14 dated 1991 wc#3
TM 9-2805-269-24P dated 1992
O P E R A T O R , U N I T , D I R E C T S U P P O R T A N D G E N E R A L S U P P O R T, M A I N T E N A N C E M A N U A L, E N G I N E , G A S O L I N E , 6 H P, M I L I T A R Y S T A N D A R D M O D E L S
( M O D E L 4 A 0 3 2 - 1 , N S N 2 8 0 5 - 0 0 - 7 7 6 - 0 4 8 3 )
( M O D E L 4 A 0 3 2 - 2 , N S N 2 8 0 5 - 0 0 - 0 6 8 - 7 5 1 2 )
( M O D E L 4 A 0 3 2 - 3 , N S N 2 8 0 5 - 0 1 - 1 3 9 - 0 5 9 6 )
( M O D E L 4 A 0 3 2 - 4 , N S N 2 8 0 5 - 0 1 - 2 7 6 - 5 9 4 6 )
TM 9-2805-269-14 Breaker Points
TM 9-2805-269-14 Electronic Ignition
Guyfang
27,246
TM 9-6115-664-13&P dated 2012
TECHNICAL MANUAL, OPERATOR AND FIELD MAINTENANCE MANUAL, INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST FOR:
5KW, 28VDC, AUXILIARY POWER UNIT (APU), MEP-952B (NSN 6115-01-452-6513)
MEP-952B EXTRACTED WIRE DIAGRAMS
M577 CONVERSION IIO 9-2350-261-34-3 dated 2003
INSTALLATION INSTRUCTION ORDER, M577A2 & M577A3 CARRIER 4.2 KW GENERATOR TO 5.0 KW AUXILIARY POWER UNIT (APU)
Guyfang
27,246
T M 9 - 2 5 2 0 - 2 5 4 - 3 4 dated 1971
T E C H N I C A L M A N U A L, DIRECT AND GENERAL SUPPORT MAINTENANCE MANUAL:
TRANSMISSION, AUTOMATIC, 2 5 2 0 - 0 6 6 - 4 2 4 0, (ALLISON DIV., GMC MODEL TX 100-1)
TM 9 2520-254-34P dated 1990
T R A N S M I S S I O N , A U T O M A T I C , E N C A S E D I N F O A M , 2 5 2 0 - 0 1 - 1 2 0 - 2 1 6 9
T R A N S M I S S I O N , A U T O M A T I C , W / C O N T A I N E R , 2 5 2 0 - 0 1 - 1 3 3 - 9 2 2 7
( A L L I S O N T R A N S M I S S I O N D I V . , G M C M O D E L T X 1 0 0 - 1 )
Guyfang
27,246
TM 9-2540-205-24&P dated 1992
Technical Manual, Organizational, DS, & GS Maintenance Manual for Heaters, Vehicular Compartment:
STEWART-WARNER
1056OC24 (NSN 2540-01-063-0691)
10560M (NSN 2540-01-071-0651)
10560M24B1 (NSN 2540-01-169-5159)
10560G (NSN 25404)1-262-6013)
HUPP
MF510B (NSN 2540-01-071-0652)
MF510C, MF60B-24V (NSN 2540-01-162-3834)
MF60A-24V (NSN 2540-00-930-8838
ESPAR
V7S (NSN 2540-01-114-7688
TM 9-2540-207-14&P dated 2007
TECHNICAL MANUAL, UNIT, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR:
HEATER, VEHICULAR COMPARTMENT, NSN 2540-01-396-2826, MODEL A-20
Guyfang
27,246
TM 9-2920-225-34 dated 1981
TECHNICAL MANUAL, MAINTENANCE, DIRECT AND GENERAL SUPPORT LEVEL FOR:
GENERATOR ASSEMBLY PRESTOLITE MODEL AMA-5102UT, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AC, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AD, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AE, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 5504AA, NSN 2920-00-475-1446
LEECE-NEVILLE MODEL 5504AB, NSN 2920-00-475-1446
LEECE-NEVILLE MODEL 2184AC, NSN 2920-00-782-1955
LEECE-NEVILLE MODEL 5300GP, NSN 2920-00-818-8635
TM 9-2920-225-34P dated 1974
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LISTS (INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS)
GENERATOR ASSEMBLY :
Guyfang
27,246
TM 55-2350-224-14 dated 1993
TRANSPORT GUIDANCE, M113 FAMILY OF VEHICLES, (M113A2, M113A3, M106A2, M125A2, M548A1,
M577A2, M667, M730A2, M741A1, M901A1, M981, M1015A1, M1059, M1064, AND M1068
TM 9-2350-275-BD 1982 wc#1
TECHNICAL MANUAL, O P E R A T O R S , O R G A N I Z A T I O N A L , D I R E C T S U P P O R T A N D
G E N E R A L S U P P O R T M A I N T E N A N C E, BATTLE DAMAGE ASSESMENT AND REPAIR F O R:
M 1 1 3 F A M I L Y, CARRIER, PERSONNEL, SELF-PROPELLED, FULL-TRACKED
Guyfang
27,246
TM 9-4910-571-12&P dated 1984
TECHNICAL MANUAL, OPERATOR'S AND ORGANIZATIONAL MAINTENANCE MANUAL, INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST , SIMPLIFIED TEST EQUIPMENT FOR INTERNAL COMBUSTION ENGINES
( NSN 4910-00-124-2554)
