- 57
- 48
- 18
- The Great State of Texas
Located in Robert Lee tx outside of San Angelo.
1989 flu419 military excavator
Family owned for 10 years, 8 of which were in storage.
Less than 200. (Yes 200) original miles
Engine hours are less than 300.
Purchased from family member 2 years ago to do some ranch work. Now complete and loooking for smaller machine! Will consider trades for mini excavator, diesel only, with cab/ac.
The flu419 is a military excavator which has a front end loader and foldable case m35c excavator on the rear, as well as remote hydraulics on hose reel for operating hydraulic equipment like chainsaws, jacks, pumps etc.
Powered by a Mercedes Benz om352 diesel engine, it’s an absolute beast. Portal axles for lots of ground clearance, 16 forward and reverse gears, with air splitter, high and low range. 4 wd with air locking differentials. This thing goes absolutely anywhere.
I replaced the entire wiring harness behind dash (damn mouse) and absolutely every light, horn, heater, everything works like new.
4 hydraulic cylinders professionally rebuilt this month as they had microscopic leaks.
2x12 volt batteries replaced last year.
New filters all around, and all fluids replaced.
New diesel primer pump although you’ll never need to prime it. Thins thing starts like a brand new truck. Will drive approximately 50 mph (I’ve had it about 45 with room to go)
You will need a large flat bed trailer to get it home. Weighs approximately 15000 lbs.
Also have military m1102 trailer that is like new I can sell also for 2000$. All aluminum high bed trailer made to tow behind humvees in the desert! Has like new 37” tires. Pintel hitch connection and the flu419 has a pintle connection as well.
Serious buyers only. Located in Robert Lee tx and can show by appointment only.
Cash sales only.
Call or text 325-305-6064
Flu419 is $32000.
Cash sales only.
Flu419 is $32000.
