Can you service a turret bearing?
alwayskaos
Lake Havasu City, Az.
So I have a used heavy duty turret bearing and was wondering if anyone knows if you can service these. I can't see anywhere how it might come apart, but it makes a little noise when spinning. Can you service these and is there a way to disassemble? Thanks!!
BLK HMMWV
570
Pasadena California
A picture of the bearing would help. I'm not sure if all the bearings are the same.
The earlier black bearings have a round plug / seal in the inside surface of the bearing ring. Slightly larger then the ball bearings inside.
In order to separate the two halves of bearing you needed to remove all the balls.
KKroger
168
KC MO
The Correct answer is ,,,, Maybe. you would likely want to wash the old grease out and put new in and if it is a sealed bearing that comes with complications like the seals.
alwayskaos
springer1981
1,184
Maine
Find TM 9-2320-280-20-3 Volume 3 then find section 11-113, Page 11-158
It describes the maintenance. I copied the page. Note the first step includes "Discard Seals" meaning you'll need new seals. I'd try to find them before continuing.
alwayskaos
So it looks like no grease or lubricant at all. Remove seal, clean, and install new seal. Seems like it should have some sort of grease in there. There is one small counter sunk screw visible. It looks like maybe the ball bearings are installed thru the hole one by one, whick then locks the two halves together.
KKroger
168
KC MO
Possibly some dri slide or something, but I can see preventing the talcum powder desert dust from sticking.
BLK HMMWV
570
Pasadena California
If I remember the ball bearings aren't steel. Some kind of composite. It's been a long time since I had one apart. I believe it's possible that they can develop a flat spot so separating the ring and inspecting them isn't a bad idea if you have time. Especially if it's not already bolted in place and then has all kinds of stuff bolted too it
