M35 winch mount and frame extenders
jesusgatos
on the road - in CA right now
Oooooooh, well that winch is a lot smaller than the PTO-driven Garwood winches that the winch mounts were designed for, and they use a completely different mounting system. BUT - if you want to buy one for me, I'll happily design/build some custom mounts for you...
Merc1973
Sykesville, MD
Winch brackets and frame extensions
...... and here you go.
For anyone interested the original drawings are made in BMP format and are available via email, only.
G.
Wow! Incredible designs. If I already had the OEM upper extension brackets and used these designs to fab my own for the lower brackets! Would they be interchangeable and fit?
