LMTV brake drum P/N cross reference?
ckouba
2,013
Oregon
Found the NSN (2530-01-360-5954) and Meritor (Meritor 3219-W-4833) numbers, but does anyone have cross-reference part number for a civilian option?
I don't currently have view access to the parts spreadsheet. Hope to soon though...
Thanks in advance,
Chris
hike
—realizing each day
935
Texas Hill Country
BRAKE SYSTEM
Brake Caging BoltOREILLYHD RB008 (Normal StockNAPATWD HD10041 ( NOT ALWAYS IN STOCK)
Brake Caging Bolt Socket (3/4 wrench or this)OREILLYLIS 49000
Brake Chamber Dust PlugTruckPro/EUCLIDE-9112NAPAE-9112Haldex9999039
Brake Screw Adjusting ScrewTruckPro/MeritorA 2297L3158
Brake inverson valveNapa/HaldexRKN 28032
Rear spring brake chamber Truckpro/Meritor/Haldex X24-3276J-10Haldex 41M001**superseded to Haldex 0912001
Click here NOTE: Other Options for Rear Spring Brake Chamber
Front Spring Brake Chamber Truckpro/Meritor E4-3276P-16hi
Exhaust Brake PACBRAKE 3126?C20373Iveco200364392Pacbrake 3116/3126- DiceseltuffC20350200364392
Spring brake diaphragm LMTV? for sure not MTV (use type 16 w/double ridges for MTV)Truck pro / NapaType 12OreillyRB-D12
Service brake diaphragm Truck Pro / NapaType 9OreillyRB-D09
Brake relay valve napa haldexN50004-D
ABS Modulator Connector CableHaldex
Brake ShoesFind local-ish Big Rig / Tractor place that does clutch/brake relineing
