Made a 2.5/2.0 hitch
aw113sgte
1,423
La Crosse, WI
Wanted to maintain a lot of the departure angle so tucked it up underneath. All 1/2 laser cut plate from Oshcut. Standard hole pattern for various hitches, has a 2.5 in these pictures, the 2.0 or pintle options will also bolt on. Will need a 14-16" drop to be at the correct ball height.
CAD files if anyone wants them: https://1drv.ms/u/c/c0b89f1e1d4b4f05/EVHApVm_DZpDglBU_dt9YjgBrqBR6jqhMamggFI2R3XV5A?e=u8CjkQ
McMaster bolts/washers/nuts:
Oshcut order: (this price would go down a ton if ordered in larger numbers.)
2.5" Receiver: https://www.buyersproducts.com/product/bolt-on-receiver-tube-6428
The 2.0" version would bolt on as well. It has a smaller footprint but the holes are already there for it.
